Home > Td5 > Indicator Stalk |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 333 |
The indicator stalk on my 2002 TD5 is getting very vague and floppy (a bit like me). It was an advisory on the last MOT and has deteriorated since then.
The bay of thieves has Lucas ones at £37.96 and various others going down to £18.88 Obviously Lucas is little more than a brand name applied to products from India and China nowadays and the quality is often questionable. Anyway, has anyone tried one of the cheaper ones or been able to compare the Lucas ones against the cheaper alternatives? |
22nd Oct 2024 10:26pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 739 |
I recently fitted a Lucas indicator switch from Paddocks..... It works, but is just as vague as the one I took off..... Just hoping that the actual switch contacts are just a little better quality than the cheaper versions
23rd Oct 2024 5:10am |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 215 |
I bought one of the super-cheap copies, it 'works'. But the self-cancelling fails to operate semi regularly. 1990 Defender 110 200TDI Camper - now converted to Td5 power
23rd Oct 2024 10:24am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 934 |
Agreed with Procta, buy yourself OE (Lucas) or genuine if you can. Its false economy otherwise.
Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
23rd Oct 2024 5:22pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2229 |
Lucas is cheap Chinese/ Indian license made tat. Avoid at all costs.
23rd Oct 2024 9:46pm |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 318 |
I fitted one of the cheap £18 ones a couple of weeks ago.
Took it out the box and thought it looked pretty good. All worked as it should. The box had nothing other than some spurious number on it. I wouldn’t be surprised if it was identical to the £37 ones, but without printing on the box. For the amount of bits it is made from, then assembly, and postage, I thought it was a bargain even if it only lasted a year. |
24th Oct 2024 2:50pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
Often or not Genuine is Lucas, Lucas is pretty good but all of them aren’t infallible build quality.
Keep an eye on the electrical connectors and that they are tight and secure, they can be a bit loose and pop off, so be sure they don’t come off before fitting. So if you do find a loose one, take it off and ever so slightly tighten the connector, and then fit so it is secure. If there is a blue indicator cancelling ring, be sure it’s fitted the same way it came off and also marries with the tangs on the back of the steering wheel if present before final fit. It isn’t complex, but is annoying if it all goes back together then you need to get back there due to something like I’ve mentioned above. Only lightly nip up the securing screw as well, they are really good for snapping and then the whole assembly is loose, a single small drip of Loctite 222 might be a good idea too but as I mentioned, the securing screw around the column only needs to be tightened just enough to secure it and no more. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Oct 2024 3:26pm |
Cheers guys.
In the end I ordered a Lucas one, however it is in an old style box and so I am hoping that it is a new old stock item and decent quality! It is due to arrive today! |
26th Oct 2024 8:48am |
