Home > My Defender > a 130 itch
Page 21 of 21 <123 ... 192021
tommobot
jst wrote:
So did some investigating. Seems to be a large variation in opening temps on stats from reputable supplier plus a varying degree of how much they open, same brand, 10deg variation on start opening and 8mm variation on how far they open!
Greater flow needed at lower engine speeds is the aim so experimenting with stats now to open early.enough,.but not too early, and have enough flow past. Will also look at electric water pumps.
Found exactly the same... I've got a M57n with 8hp... Ideally I'd cruise around in 8th at low revs, which it seems quite comfortable doing, the ODB temp reading flies up and triggers rad fans almost instantly.
Will be interested to see how you get on with EWP, presume this in lieu of the OEM water pump, rather than alongside?
Post #1046552 23rd Sep 2024 10:36am
jst
EWP is a through flow so for now i have left a stat and fitted the EWP in the top hose.
EWP has its own controller and will only come on once the stat has opened.
Stat wise, some of the branded ones only opened 5mm at max opening. should be 11 or so. i now have a proper opening stat that open at the right temp plus the EWP fitted to increase circulation with stat open at low engine speeds. will let you know how it goes. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1046575 23rd Sep 2024 1:29pm
sako243
jst wrote:
So what do people think was the problem?
No brake signal to the ECM that controls the alternator to let it know that it can initiate full charging?
Normally the smart alternators try and refrain from charging the battery until it's fuel efficient to (such as under braking or coasting). Not quite sure why it recharges straight away, maybe that's just the way that the BMW bods have programmed it to ensure it recovers from starting the vehicle. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #1046582 23rd Sep 2024 1:50pm
jst
^^^^ yes that a good avenue to test, but nope. simpler than that. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1046585 23rd Sep 2024 3:02pm
jst
Another top weekend away with some off roading mates inidnWales at the weekend. The m57 130 continues to impress and brings a big smile to my face. Effortless driving and even goes off road! More off road than some would venture within
that woods!
Angle makes it look long than the cj and trailer combined!
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1049376 21st Oct 2024 8:26pm
jst
A few others on here there too.
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1049378 21st Oct 2024 8:28pm
jst
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1049379 21st Oct 2024 8:29pm
Joel
United Kingdom 2002 Defender 110 Td5 DCPU Santorini Black
This might be a daft question, regarding the M57 conversion, I think I have my head around most of it, however, where do you get the speedo feed from - on the TD5 it comes from the ECU I think, not sure where it comes from with the M57 conversion - where does yours come from?
I'm also going to be adding ABS to mine, I managed to procure a TD5 XS loom with heated seats, electric windows and other useful goodies. With it came the ABS and AS10 so I can add central locking as well.
Joel 110 DCPU TD5 02
130 DCPU TD5 04
Post #1049899 26th Oct 2024 10:23pm
jst
It's all part of the control box that links engine loom to puma ecu harness.
What ever you do don't drill any holes or join anything together with a nut and bolt! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1049928 27th Oct 2024 1:28pm
