Home > My Defender > a 130 itch
Page 22 of 22 <123 ... 202122
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Ah ok, it might be worth getting a lower flow rate like the 115 model then you reckon?
The stat is a Mahle which is the best I can get to do what it’s supposed to. Tested opening at 88 degrees which is what lead me to believe better flow at low revs may help.
Thanks for the help and insight again James
Post #1063531 21st Mar 2025 2:38pm
jst
How much does the stat open? What the range of movement 12mm or more? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1063578 21st Mar 2025 11:50pm
BuckBlu110
Unfortunately at the time I didn’t actually measure how much it opened, it appeared to open its full range of motion, a good 10mm by eye.
Post #1063586 22nd Mar 2025 7:59am
jst
A correctly functioning stat is crucial. Of the Mahle ones I have only two from 8 opened at correct temp and opened fully. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1063642 22nd Mar 2025 9:27pm
BuckBlu110
I’ll whip the stat out again and have a measure up as soon as I can.
Looks like Marcus at MWmachines is working on a thermostat to help with this problem so I may look into that at some stage.
One last question and I’ll leave you alone, Davis Craig recommend drilling two holes to help circulation, did you do this or do you think it’s not necessary if the stat is (should be) open when the pump switches on?
Post #1063650 22nd Mar 2025 11:35pm
jst
Mine is connected is such a way it can only come on when the stat is open so, no I didn't drill any holes.
Marcus and I have been discussing stats alot. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1063678 23rd Mar 2025 3:18pm
BuckBlu110
Thanks again James, all very appreciated information Thumbs Up
Post #1063681 23rd Mar 2025 4:09pm
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
jst wrote:
RoadForce wrote:
That's one lovely 130, very well done! I noticed you have full length rock sliders / upgraded sills, where did you source them? Or did you fabricate those yourself? Most I find are too short for a 130 (like the ones previously on your car).
Safari equip sills. Well made not so great finish
Thanks, will have a look Thumbs Up
Can you elaborate on the "not so great" finish? Is it fit or longevity you're not so impressed with? Defender 130 HCPU Td5 MY2000
Post #1064036 27th Mar 2025 4:39pm
jst
the paint comes off Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1064071 27th Mar 2025 9:07pm
RoadForce
Good to know, thanks! Defender 130 HCPU Td5 MY2000
Post #1064591 3rd Apr 2025 4:29pm
