Home > Td5 > 2001 TD5 with 15p engine? |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 173 |
It's possible as Y reg ran til 31 Aug 2001 and the first pre-producton 2002 models came out in Feb 2001, yet there's only 15 of them.
Best to check the actual engine number? If its 15P0xxxxA then it's a genuine early one. LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
16th Oct 2024 7:59pm |
Jim1988 Member Since: 26 Oct 2017 Location: Derbyshire Posts: 233 |
Thanks mate, I’ll check the engine number in the morning 🤓.
16th Oct 2024 11:17pm |
Hi mate, you mean this number? So it’s definitely a 15p engine? But doesn’t mean it’s factory? Click image to enlarge |
17th Oct 2024 12:42pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1596 |
I have seen them in pre “new dash” with 15P sometimes even with the cylindrical fuel cooler.
17th Oct 2024 9:53pm |
Just realised yours is the red 90 from the other thread that you bought recently.
Your photo is definitely 15P, but i've looked up your vehicle and the engine number recorded with the DVLA is a 10P, so I suspect the engine has been changed..... but what's interesting is that engine is a very early 15P. If an engine with that number was in a 2002MY vehicle it would have been built around the end of August 2001 (the first 1000 or so vehicles). Most likely its had an early 15P Td5 engine put in it from another Defender, potentially during the galv chassis rebuild? LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
18th Oct 2024 12:46am |
