Home > Faults & Fixes (L663) > D250 - Occasional hesitation under partial load
Page 2 of 3 <123>
Telemarkskier
Re: D250 - Occasional hesitation under partial load
BrettMRC wrote:
I've noticed a few times now that our D250 hesitates/stutters when driving under partial throttle, (example being cruising on an A road).
The symptom is a very brief flatspot/stutter/hesitation that probably lasts no more than a second.
Anyone else had similar?
I have noticed a similar stutter/hesitation under the following: cruise control set 60-72mph, then overriding with the accelerator brings on a stutter as if there is a brief electronic battle for who is in control is going on. Hesitation clears after a coupe of seconds. 2020 Defender 110 SE 240D: Fuji White.
2011 Freelander 2 SD4 HSE
2007 Freelander2 HSE (man)
Post #1048830 16th Oct 2024 9:04am
A1C6
Australia
Retroanaconda wrote:
Plug it in to a proper LR-compatible scanner
May be a wee bit offtopic but what are some good scanner options for Defenders?
Post #1048842 16th Oct 2024 10:38am
Moo
Ukraine
GAP IID Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1048900 16th Oct 2024 6:14pm
XRM
Just had a run up to Scotland from Devon and getting this slight hesitation also on a D300 with 4500 miles on the clock and starting to notice it around town now, did anyone get an answer to what it could be from the dealers ?
Post #1050254 30th Oct 2024 9:57am
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Mine was at the dealers last week and absolutely no fault codes recorded or present - they drove it but could not replicate the problem so have recorded the issue against the car and said to just continue to drive it.
If and when it gets worse I have to take it back. Gas, Grass Or Ass - Nobody Rides For Free
"UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #1050336 31st Oct 2024 10:57am
XRM
Thanks for that Japseroony it was not so noticeable on the run south again May just have to live with it I’ll see how it goes. Thumbs Up
Post #1050338 31st Oct 2024 11:04am
Moo
Ukraine
36,000 miles in two years and never experienced it. Confused Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1050340 31st Oct 2024 11:56am
BrettMRC
Mines probably done it once or twice more that I've noticed since I made the OP.
Nothing showing on the codes yet.
Post #1051298 11th Nov 2024 8:26am
BrettMRC
I've just had an update come through that claims to resolve hesitancy issues...
Will see what it's like once it's finished updating!
Post #1053321 29th Nov 2024 12:59pm
91dm
Ireland
Another forum member had this issue and was resolved by cleaning out the pipe shown.
A 3.0 diesel D200 model.
Post #1053947 5th Dec 2024 8:57pm
lightning
My D250 does from time to time a little stutter or lurch, it happens on a light throttle at lower speeds and appears to be where the transmission can't decide what to do.
So it will disengage and then suddenly reselect a gear (that's what it feels like) and you get a little lurch when it does it.
Post #1053957 5th Dec 2024 11:16pm
91dm
Ireland
‘Lighting’, that sounds very similar to what I was experiencing.
I originally thought it was the gearbox, it feels like someone has flicked the ignition off for second or slipping a gear. It only did it at low rpm (around 1100). I noticed no mid range power as it got worse.
Post #1053977 6th Dec 2024 9:21am
lightning
Where was the pipe that needed cleaning out?
Post #1054059 7th Dec 2024 12:49pm
lightning
Did the update work?
Post #1054060 7th Dec 2024 12:50pm
Oswiperus
It's on page 2 of this thread:
https://www.defender2.net/forum/topic90462.html?highlight=egr 110 D300 SE Tasman blue
Post #1054069 7th Dec 2024 1:32pm
Page 2 of 3 <123>
