![]() | Home > Faults & Fixes (L663) > D250 - Occasional hesitation under partial load |
A1C6 Member Since: 15 Oct 2024 Location: Australia Posts: 61 ![]() ![]() |
May be a wee bit offtopic but what are some good scanner options for Defenders? |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1469 ![]() ![]() |
GAP IID
XRM Member Since: 02 Feb 2024 Location: UK Posts: 3 ![]() ![]() |
Just had a run up to Scotland from Devon and getting this slight hesitation also on a D300 with 4500 miles on the clock and starting to notice it around town now, did anyone get an answer to what it could be from the dealers ?
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 843 ![]() ![]() ![]() |
Mine was at the dealers last week and absolutely no fault codes recorded or present - they drove it but could not replicate the problem so have recorded the issue against the car and said to just continue to drive it.
If and when it gets worse I have to take it back. Gas, Grass Or Ass - Nobody Rides For Free "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
Thanks for that Japseroony it was not so noticeable on the run south again May just have to live with it I’ll see how it goes.
36,000 miles in two years and never experienced it.
BrettMRC Member Since: 02 Jan 2024 Location: South West Posts: 29 ![]() ![]() |
Mines probably done it once or twice more that I've noticed since I made the OP.
Nothing showing on the codes yet. |
I've just had an update come through that claims to resolve hesitancy issues...
Will see what it's like once it's finished updating! |
91dm Member Since: 26 Feb 2024 Location: Ireland Posts: 35 ![]() ![]() |
Another forum member had this issue and was resolved by cleaning out the pipe shown.
A 3.0 diesel D200 model. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3060 ![]() ![]() |
My D250 does from time to time a little stutter or lurch, it happens on a light throttle at lower speeds and appears to be where the transmission can't decide what to do.
So it will disengage and then suddenly reselect a gear (that's what it feels like) and you get a little lurch when it does it. |
‘Lighting’, that sounds very similar to what I was experiencing.
I originally thought it was the gearbox, it feels like someone has flicked the ignition off for second or slipping a gear. It only did it at low rpm (around 1100). I noticed no mid range power as it got worse. |
Where was the pipe that needed cleaning out?
Did the update work? |
Oswiperus Member Since: 12 Aug 2020 Location: Chelmsford Posts: 54 ![]() ![]() |
It's on page 2 of this thread: https://www.defender2.net/forum/topic90462.html?highlight=egr 110 D250 S Hardtop Tasman Blue |
