![]() | Home > Puma (Tdci) > Broken dipstick |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 628 ![]() ![]() |
How did that happen? Is what I'd be more concerned about.. If its settled in the sump it will likely do no harm, I think you will be lucky to see it again unless you have the sump off.. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
It would bother me. I'd drop the sump and fish it out, it's a simple job, but you'll likely need a new sump as its hard to not deform the flange.
Thinking about it you might be able to fish it out through the drain hole with a bit of wire or something. Try that first. 2007 110 TDCi Station Wagon XS |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
I was going to say wouldn’t a magnet draw it out the oil drain hole in the pan, but being non ferrous the tip won’t do that readily.
I expect some wire fashioned into a loop might find it, but it would be a bit like fishing literally and you’d have to be careful the wire didn’t break off or that would be even more of a problem. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 Last edited by custom90 on 5th Oct 2024 6:49pm. Edited 1 time in total |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3348 ![]() ![]() ![]() |
It happened to me a few years back, I replaced the sump to get it out even though it was likely overkill. WARNING.
This post may contain sarcasm. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3652 ![]() ![]() ![]() |
https://www.defender2.net/forum/topic20217...n+dipstick DEFENDER 90 TDCI XS,
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
Thanks, did not do a search, was not aware that it is "common"
![]() I have a soldered fitting inside the sump for oil temperature, so I hesitate a bit dropping the sump. But thanks for your suggestions!! |
ksv Member Since: 04 Nov 2014 Location: Volgograd Posts: 19 ![]() ![]() ![]() |
Mine lives in the pan more than five years.
