Home > Td5 > Coolant temperature readings with Nanocom
Printerjohn
United Kingdom 2006 Defender 110 Td5 XS CSW Barolo Black
I'm touring in France, have connected my nanocom as my engine overheated and temp gauge went to maximum. Since then that has not happened, but nanocom shows temperature range of 95 - 104, with a peak once of 114. During all of this the built in gauge showed normal. Should I disconnect Nanocom and continue, or should I head for the ferry port ASAP? What are the groups feelings?
www.muddymarge.com
Post #1047668 4th Oct 2024 12:44pm
jst
a puma gauge doesnt budge until 112 deg. expect there is similar in the td5.
is it actually hot, smell hot, feel hot? or is it a sender issue? hoses hard? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1047674 4th Oct 2024 2:02pm
Printerjohn
Doesn't smell hot. Hoses feel hard. I measured the resistance of the temperature sender with my multimeter, with engine not running, but reasonably hot it was 230 ohms which I think is about right.
Post #1047675 4th Oct 2024 2:12pm
landy andy
The temp gauge shooting into the red is telling you there is an issue, not that the vehicle is hot necessarily.
So the nanocom is actually telling you the truth. It is something else that it wasn’t happy with.
Post #1047678 4th Oct 2024 3:43pm
Printerjohn
A garage in the south of France has taken a look, and it was the thermostat not opening. The mechanic did what he called an 'African' repair (and looking at the photos on his garage walls he has a lot of experience of driving his classic range rover in Africa) which involved wedging the thermostat open. The temperature now tops out at 65C, initially there was quite a bit of steam and pressure at the expansion bottle cap which he told me was probably my head gasket or head gone. But this has reduced after driving for a couple of hours to another garage where another mechanic looked it over, and thinks I may have got away with it. We have some weeks still in France so will drive slowly back with the nanocom on all the time monitoring, and work our way back to the ferry at Cherbourg in small stages.
Post #1048142 9th Oct 2024 4:50pm
