![]() | Home > Puma (Tdci) > Puma 2.4 TdCI dashboard amber Engine Light / EGR |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3351 ![]() ![]() ![]() |
It’s quite easy to replace yourself. https://www.landrovermonthly.co.uk/article...egr-valve/
If you don’t fancy having a go just take it to a local garage on the island. It’s a Ford engine so most will have experience changing them. WARNING. This post may contain sarcasm. |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 642 ![]() ![]() |
I struggle to see how you can effectively clean an egr valve and pipework without removing it and cleaning and checking .. I'd be very careful about spraying any sort of combustible cleaner into the intake of a diesel..the engine can run on..it's a bit scary and I'm sure could cause damage.. I know you are low mileage but I'd be removing and checking the valve and the inlet manifold /throttle body while you are there.. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1828 ![]() ![]() ![]() |
Unless you've used it solely for touring off the island, 5000 4 mile journeys will have choked everything up - new EGR and a good clean out and it will be good for another 20000!
hth Keith |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2161 ![]() ![]() |
In your situation, given you are likely doing many short journeys and will continue to do so. I would remove your inlet manifold and give it a good clean as it will be full of oily soot. Then have your EGR mapped out by BAS, blank the EGR cooler at its input. Remove EGR cooler coolant pipes and join together, then fit a Provent 200 catch can.
Your engine will run much better, will stay much cleaner, will pass an mot as the EGR will be visible and emissions will be fine and you won’t be bothered with any EGR issues ever again. |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
^^^^^^^^^^^^^^^^^^^^^This!
