Home > Faults & Fixes (L663) > Matrix led halo failure |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1115 |
Just had my left drl fail. Noticed it in the reflection from the car in front. I guess itโs a mot failure so will have to be fixed. Mine are matrix led headlamps so expecting a sizeable bill!!
Mine has also just turned 31000 and will be 4 years old in January. I will be phoning Williams JLR and will ask for a sympathetic post warranty claim, but not holding out much hope. I think I read somewhere that they are sealed units and canโt be fixed. ๐ 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
20th Sep 2024 12:38pm |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1199 |
check out Powerful Uk, Simon did a tutorial on this subject
https://www.powerfuluk.com/collections/new...l663-right another solution is to 'disable' the other (hand working) 'signature led' Those of you who had the 'S' model will remember this model did NOT come with 'Signature halo leds' As long as you have the two square leds in each of the cluster, that will pass an MOT Last edited by LR Nuts on 20th Sep 2024 12:52pm. Edited 1 time in total |
20th Sep 2024 12:45pm |
Yes just seen that. He says to check that LR might honour an out of warranty replacement. Worth a try before trying a self repair. 2021 Defender 110 X-Dynamic HSE D300 MHEV
20th Sep 2024 12:48pm |
just edited (added to) my previous reply.
20th Sep 2024 12:53pm |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 |
It is Repair able, heat the unit up in the oven, be patience by tearing the lens off , replace the led unit.
use butyl sealant for rebuild , see the links in this thread on Landrover forums.com https://landroverforums.com/forum/2020-def...769/page3/ Sealant https://www.amazon.com/dp/B08SMPRKG6?_enco...wisterOG=1 No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
20th Sep 2024 12:54pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2917 |
Loads of failures on the US Defender forum. Possibly due to the hotter climate? Varied success in claiming from LR.
New headlights are a silly price. Powerful U.K. sell a repair kit. |
20th Sep 2024 4:59pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20590 |
Be sure to check itโs not grounding as LEDโs can be sensitive to faults like that, voltage or poor connections. Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
20th Sep 2024 5:35pm |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 160 |
Happily that's me. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
20th Sep 2024 9:16pm |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 232 |
happily! yes!!! but it is much uglier!!!๐ Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
20th Sep 2024 10:02pm |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 |
Halo failure is also a common reported issue in Australia
Had both Front headlights replaced by LR under warranty because of Halo failures in the 12 months The service manager stated that the replacement headlights had different part numbers to the originals fitted on our MY20.5, so fingers crossed they have improved the "resiliency" of the halo and they do not fail again no doubt i have jinxed it .. yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
22nd Sep 2024 12:57am |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 136 |
16months and 20000km in, no issues, fingers crossed. I have 5yrs factory warranty and 5yrs extended platinum warranty, so should be covered in the event of a component failure. Similar with our Jeep, extended warranty has paid for itself with full u-connect system replacement (jeeps pivi equivalent) as well as several other key part replacements: water pump and coolant overflow bottle, idle control solenoid, lower wishbones support plates etc.
28th Sep 2024 2:30am |
