Home > Faults & Fixes (L663) > Matrix led halo failure
Coollachella
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
The front offside led halo matrix on my 2021 D250 defender has failed. Has anyone had a similar issue. The car has done about 30k miles. The rest of the headlamp unit seems to be working as it should. The fuses are fine and all connections are connected. Thanks.
Post #1046281 20th Sep 2024 12:49pm
Gareth
Just had my left drl fail. Noticed it in the reflection from the car in front. I guess it’s a mot failure so will have to be fixed. Mine are matrix led headlamps so expecting a sizeable bill!!
Mine has also just turned 31000 and will be 4 years old in January.
I will be phoning Williams JLR and will ask for a sympathetic post warranty claim, but not holding out much hope.
I think I read somewhere that they are sealed units and can’t be fixed. 😞 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #1046284 20th Sep 2024 1:38pm
LR Nuts
check out Powerful Uk, Simon did a tutorial on this subject
https://www.powerfuluk.com/collections/new...l663-right
another solution is to 'disable' the other (hand working) 'signature led'
Those of you who had the 'S' model will remember this model did NOT come with 'Signature halo leds'
As long as you have the two square leds in each of the cluster, that will pass an MOT
Post #1046285 20th Sep 2024 1:45pm
Gareth
Yes just seen that. He says to check that LR might honour an out of warranty replacement. Worth a try before trying a self repair. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #1046287 20th Sep 2024 1:48pm
LR Nuts
just edited (added to) my previous reply.
Post #1046288 20th Sep 2024 1:53pm
Defendit..
Netherlands
It is Repair able, heat the unit up in the oven, be patience by tearing the lens off , replace the led unit.
use butyl sealant for rebuild , see the links in this thread on Landrover forums.com
https://landroverforums.com/forum/2020-def...769/page3/
Sealant
https://www.amazon.com/dp/B08SMPRKG6?_enco...wisterOG=1 No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1046289 20th Sep 2024 1:54pm
lightning
Loads of failures on the US Defender forum. Possibly due to the hotter climate? Varied success in claiming from LR.
New headlights are a silly price.
Powerful U.K. sell a repair kit.
Post #1046309 20th Sep 2024 5:59pm
Be sure to check it’s not grounding as LED’s can be sensitive to faults like that, voltage or poor connections. TheThunderRolls🇬🇧🇺🇸
Post #1046315 20th Sep 2024 6:35pm
WizzardPrang
Happily that's me. Thumbs Up Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #1046350 20th Sep 2024 10:16pm
ruben
Spain
happily! yes!!! but it is much uglier!!!😜 Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1046352 20th Sep 2024 11:02pm
zilch
Australia
Halo failure is also a common reported issue in Australia
Had both Front headlights replaced by LR under warranty because of Halo failures in the 12 months
The service manager stated that the replacement headlights had different part numbers to the
originals fitted on our MY20.5, so fingers crossed they have improved the "resiliency" of the halo and
they do not fail again Thumbs Up no doubt i have jinxed it Whistle .. yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #1046437 22nd Sep 2024 1:57am
DFNDER
Australia
16months and 20000km in, no issues, fingers crossed. I have 5yrs factory warranty and 5yrs extended platinum warranty, so should be covered in the event of a component failure. Similar with our Jeep, extended warranty has paid for itself with full u-connect system replacement (jeeps pivi equivalent) as well as several other key part replacements: water pump and coolant overflow bottle, idle control solenoid, lower wishbones support plates etc.
Post #1047048 28th Sep 2024 3:30am
