![]() | Home > Maintenance & Modifications > dual battery? |
drewster Member Since: 13 Jun 2011 Location: south coast brockenhurst Posts: 226 ![]() ![]() ![]() |
twin numax from tanya
much cheaper than optima
http://www.tayna.co.uk/Numax-CXV-X-1000-Amp-P7632.html |
coln18 Member Since: 01 Nov 2011 Location: Loch Lomond Posts: 45 ![]() ![]() |
Many thanks mate i will check that out in a minute or two. Col |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 ![]() ![]() ![]() |
Twin Odyssey 1500's in the Devon battery tray, National Luna dual battery system. Faultless performance for years on TD5 (with Webasto, Engel etc etc) and now faultless on Puma with similar usage. D300 HSE 110
Thanks for the answers guys, this really is a good site for people trying to help you out when your setting about doing new things to the defender.
![]() Is it a fairly straight forward thing to do, the split charge/dual battery set up. Not had a chance to read into it yet as i only noticed the clock running behind this morning. Col |
We run 3 Land Rovers all with Odyssey batteries in
Disco 2 with single Odyssey 1500 Red 110 with twin Odyssey 1700's and a Genesyz split charge system Black 110 with twin Odyssey 1500's and an IBS battery management system. Have used Optimas in the past, now use Odysseys only in our vehicles! If going for twin batteries ensure both batteries are a combined starter/leisure battery. Wire most of your auxiliary items to the second battery. (Via a decent fuse box which also has common negative bus bars) There are many ways of achieving split charging. The three main contenders for battery management systems are IBS available from 4x4 Overlander HEREat £225 Genesyz available from Devon 4x4 hereat £269 National Luna available from APB Trading HERE at £272 Of the three I have no personal experience of the National Luna The Genesyz on our red 110 does not seem to like it if one of the batteries goes low and just goes around its start up sequence cycle. The IBS on our black 110 has been good. (Declared interest here we sell the IBS system) The only IBS system I have know to have any problems with is one that one of our customers has recently fitted. We are trying to identify the actual cause of the problem with the Swiss manufacturers at this moment in time. YES there are lots of other ways of charging twin batteries Brendan |
Thanks Brendan for all your help i will have to have a good read into to it before i decide what to go for.
Col |
