Home > Maintenance & Modifications > dual battery?
coln18
dual battery?
Hi Guys, with all the extras i have been adding to my 110 lately, skytag, eberspacher, heatshot unit etc i noticed this morning that the clock was suddenly running 40 minutes slow, so i think it may be time to add that extra battery to the 110 as the skytag runs off it permanently i thought it would be a good idea.
Does anyone have a good link to fitting it and which is the best one to go for, best place to get it from etc
Many thanks in advance
Col
Post #104696 5th Dec 2011 12:15pm
drewster
Wales 1997 Defender 90 300 Tdi CSW Epsom Green
twin numax from tanya
Post #104697 5th Dec 2011 12:17pm
drewster
Post #104699 5th Dec 2011 12:21pm
coln18
drewster wrote:
much cheaper than optima
http://www.tayna.co.uk/Numax-CXV-X-1000-Amp-P7632.html
Many thanks mate i will check that out in a minute or two.
Col
Post #104701 5th Dec 2011 12:27pm
leeds
Numex are a sealed lead acid battery.
Optimas, enough said
Odysseys are probably the best AGM batteries currently available for the 4x4 market.
As much as it pains me to say this we can not currently match the Devon 4x4 offer HERE Big Cry Big Cry Big Cry
For split charging systems we use IBS here
Brendan
Post #104707 5th Dec 2011 1:05pm
18stone
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Twin Odyssey 1500's in the Devon battery tray, National Luna dual battery system. Faultless performance for years on TD5 (with Webasto, Engel etc etc) and now faultless on Puma with similar usage. D300 HSE 110
Post #104753 5th Dec 2011 4:15pm
coln18
Thanks for the answers guys, this really is a good site for people trying to help you out when your setting about doing new things to the defender. Thumbs Up
Is it a fairly straight forward thing to do, the split charge/dual battery set up. Not had a chance to read into it yet as i only noticed the clock running behind this morning.
Col
Post #104755 5th Dec 2011 4:27pm
leeds
We run 3 Land Rovers all with Odyssey batteries in
Disco 2 with single Odyssey 1500
Red 110 with twin Odyssey 1700's and a Genesyz split charge system
Black 110 with twin Odyssey 1500's and an IBS battery management system.
Have used Optimas in the past, now use Odysseys only in our vehicles!
If going for twin batteries ensure both batteries are a combined starter/leisure battery. Wire most of your auxiliary items to the second battery. (Via a decent fuse box which also has common negative bus bars)
There are many ways of achieving split charging. The three main contenders for battery management systems are
IBS available from 4x4 Overlander HEREat £225
Genesyz available from Devon 4x4 hereat £269
National Luna available from APB Trading HERE at £272
Of the three I have no personal experience of the National Luna
The Genesyz on our red 110 does not seem to like it if one of the batteries goes low and just goes around its start up sequence cycle.
The IBS on our black 110 has been good. (Declared interest here we sell the IBS system) The only IBS system I have know to have any problems with is one that one of our customers has recently fitted. We are trying to identify the actual cause of the problem with the Swiss manufacturers at this moment in time.
YES there are lots of other ways of charging twin batteries
Brendan
Post #104760 5th Dec 2011 4:47pm
coln18
Thanks Brendan for all your help i will have to have a good read into to it before i decide what to go for.
Col
Post #104799 5th Dec 2011 6:35pm
