Home > Maintenance & Modifications > Wiper motor. Genuine or OEM?
Zed
My front wipers are stopping on the screen when using intermittent wipe and not parking at the bottom when normal speed. Using the search function on here it looks like the park switch is acting up. I already have the switch plus wiper boxes (Genuine) but thought I might as well do the motor while the dash is out. Genuine motors are 3 times the price so I wondered if anyone has experience with OEM? Not britpart obvs. WARNING.
Post #1046793 25th Sep 2024 5:06pm
I fitted an "OEM" motor when the high speed brush wore out on mine and it has been every bit as good as the original so far. I'd avoid the ultra-cheap or blue-box ones but those aside I suspect there is little to choose.
Genuine parts prices are excessive now which is a shame and, I suspect, largely the result of JLR's incredibly expensive choice of supply chain service provider.
Post #1046796 25th Sep 2024 5:37pm
Zed
That’s the answer I was hoping for. Thank you. WARNING.
Post #1046797 25th Sep 2024 5:43pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi
I fitted an OEM wiper motor and it performs brilliantly.
Jim
Post #1046801 25th Sep 2024 6:33pm
Zed
Thanks Jim. WARNING.
Post #1046810 25th Sep 2024 7:47pm
I think OEM would be okay, just use genuine wheel boxes and cable etc at least I would anyway.
Britpart as mentioned, best avoided there is a few others that might not be great but OEM motor I think would be okay.
I wouldn’t take it for granted that you need to change it unless you have to, I kept mine in use as it had nothing wrong with it.
But if there is something wrong with it then that’s sensible, good time to change the park switch too. WeWillWin🇬🇧🇺🇸
Post #1046815 25th Sep 2024 9:20pm
Zed
Yep, those were my thoughts too. I just ordered the OEM motor from LR Parts
but I already have all the other bits and they are genuine. WARNING.
Post #1046819 25th Sep 2024 10:01pm
HardCharger
I try to go genuine LR if the prices are reasonable enough, otherwise, OEM and "G" Suffixed items are the way to go. I don't go with the blue box surprises unless they are the OEM or "G" suffixed manufacturer.
If the case is the latter, I check if there is an upgrade part somewhere out there that is of better quality. Failing that, I order the OEM or G blue box part and hope for the best. No Better Friend, No Worse Enemy
Post #1046830 26th Sep 2024 3:56am
