Home > General & Technical (L663) > "Oil Service"
lightning
"Oil Service"
Re my previous thread.
My Defender is telling me it needs an "oil service" at around 16,500 miles.
l forgot to ask
Does anyone know....
Can l do this oil change myself, and reset the service indicator. Or is it necessary to take it to a dealer. Obviously it needs to go in to the dealer for the first scheduled service at 21,000 but l wanted to know if the interim "oil service" is registered on the system. l don't want to invalidate the warranty.
Post #1044925 5th Sep 2024 2:58pm
whiterdesign
Odd one that , why is it saying it needs a service, usually 2 years or 21000 miles.
You can reset the indicator yourself, there’s loads of YouTube videos of how to do it , but it then sets the next service interval to be 730 days after, I.e 2 years 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #1044937 5th Sep 2024 4:07pm
lightning
l don't know if "oil service" means a 21,000 mile
service, or just an interim oil change.
l will call the LR dealer and see if they can shed some light on it.
Post #1044938 5th Sep 2024 4:27pm
LR Nuts
My 33,000 service is been done tomorrow by my indy. will let you know what they do.
Post #1044939 5th Sep 2024 4:46pm
JonathanP
United Kingdom 1998 Defender 90 300 Tdi SW Caledonian Blue
I did an oil service myself along with a new oil filter. I then reset the oil service counter by using the method that uses the bonnet open, pedal press method or something like that. I can not find where I put the instructions, but they were from this Forum. It reset the service oil counter but not the main engine / full service counter, it is something like Switch on, open driver’s door, open bonnet, press brake then accelerator and hold for 30 seconds.
Post #1044941 5th Sep 2024 5:18pm
whiterdesign
?si=yWolJcx1Cw0btIzu 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #1044947 5th Sep 2024 6:09pm
DrRob
It’s asking for new oil as it’s got too diluted from DPF regenerations. Has it been changed since new?
Twelve months or 10,000 miles is what I’d be aiming for. The 2 year 20 odd thousand recommended seems bonkers to me Shocked
Anyway, do the oil filter and new oil yourself and reset the indicator using the pedal press combo routine or use a plug in like a GAP IID Thumbs Up MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1044954 5th Sep 2024 6:58pm
lightning
Yes the oil and filter has been changed at 5,000 and 10,000 miles.
But the Defender won't "know" it's been changed, it will assume it's still on the original oil.
Post #1044958 5th Sep 2024 7:38pm
DrRob
Makes sense as it’s not previously been told it has new oil hence why it’s asking for new oil now 👍
On my L322 I used to use the gap iid to reset service interval when I changed the oil between annual services. It basically told the ECU to start its oil dilution calculations from zero 👍👍👍 MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1044960 5th Sep 2024 7:45pm
zilch
Australia
This week our P400 had its 3rd major service, the dealer under took a 72 month service
schedule on ours which is just under 4 years old. as it goes off road and tows we have
also have interim oil and filter changes done approx at each 12,000 km mark, interims done by the
same dealer who does the major ones, but they never reset the service counter unless it had the main scheduled service done, interims do not count. yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #1045075 7th Sep 2024 12:14am
