![]() | Home > General & Technical (L663) > "Oil Service" |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 272 ![]() ![]() |
Odd one that , why is it saying it needs a service, usually 2 years or 21000 miles.
You can reset the indicator yourself, there’s loads of YouTube videos of how to do it , but it then sets the next service interval to be 730 days after, I.e 2 years 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3015 ![]() ![]() |
l don't know if "oil service" means a 21,000 mile
service, or just an interim oil change. l will call the LR dealer and see if they can shed some light on it. |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
My 33,000 service is been done tomorrow by my indy. will let you know what they do.
JonathanP Member Since: 01 Jun 2024 Location: Barnard Castle Posts: 28 ![]() ![]() ![]() |
I did an oil service myself along with a new oil filter. I then reset the oil service counter by using the method that uses the bonnet open, pedal press method or something like that. I can not find where I put the instructions, but they were from this Forum. It reset the service oil counter but not the main engine / full service counter, it is something like Switch on, open driver’s door, open bonnet, press brake then accelerator and hold for 30 seconds.
?si=yWolJcx1Cw0btIzu 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 240 ![]() ![]() |
It’s asking for new oil as it’s got too diluted from DPF regenerations. Has it been changed since new?
Twelve months or 10,000 miles is what I’d be aiming for. The 2 year 20 odd thousand recommended seems bonkers to me ![]() Anyway, do the oil filter and new oil yourself and reset the indicator using the pedal press combo routine or use a plug in like a GAP IID ![]() 1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
Yes the oil and filter has been changed at 5,000 and 10,000 miles.
But the Defender won't "know" it's been changed, it will assume it's still on the original oil. |
Makes sense as it’s not previously been told it has new oil hence why it’s asking for new oil now 👍
On my L322 I used to use the gap iid to reset service interval when I changed the oil between annual services. It basically told the ECU to start its oil dilution calculations from zero 👍👍👍 MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung 1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 ![]() ![]() |
This week our P400 had its 3rd major service, the dealer under took a 72 month service
schedule on ours which is just under 4 years old. as it goes off road and tows we have also have interim oil and filter changes done approx at each 12,000 km mark, interims done by the same dealer who does the major ones, but they never reset the service counter unless it had the main scheduled service done, interims do not count. yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
