Home > General & Technical (L663) > Remote height adjustment |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1159 |
It was posted earlier, but thanks for the reminder
2nd Sep 2024 8:55am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2876 |
Interesting feature.
But why would you want to raise or lower the vehicle with the key fob? There must be a good reason, or it wouldn't be in the programming, but l can't see it. |
2nd Sep 2024 2:49pm |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 269 |
Hooking up a trailer or Caravan 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
2nd Sep 2024 3:52pm |
l've got coil springs on my Defender so it's at the higher level all the time, and l've never had an issue attaching our caravan.
Just raise the 'van or trailer using the jockey wheel and then lower it down on to the tow ball. Once the jockey wheel is off the ground, pull the handle and "CLUNK" the receiver drops on to the tow ball and you know it's attached. |
2nd Sep 2024 4:53pm |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 491 |
Perfect for fly-by facebook marketplace furniture collection:
Ditch the Def outside the seller's house - preferably ramped up the kerb on double yellows Whack the Hazards on. Complete the exchange. Return to vehicle whilst lowering the backend Pretend that extra 7mm helped.. |
4th Sep 2024 10:30am |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1409 |
I use it to drop it for elderly members of my family or loading when approaching the car.
Useful feature. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
4th Sep 2024 10:38am |
moo, ....... also good for 'LADIES IN-HEELS' ........
4th Sep 2024 10:51am |
Or anyone in heels..... Eiger Grey MY23 D250 SE with bits. Known as Noddy.
4th Sep 2024 9:46pm |
Harveyj09 Member Since: 28 Jul 2024 Location: Doncaster Posts: 2 |
Is there a way to get it even lower, when parked, without purchasing anything? Eg a secret menu or button press to get an extra low access height? I’ve read the boxes can get you an extra 40-50mm lower.
5th Sep 2024 10:04pm |
I'm pretty sure you have the basic lowered 'access height' when parked
and then the 'remote lowering' drops it a little further (same as the controls in the boot of the vehicle). |
6th Sep 2024 10:08am |
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 85 |
It works on models prior to the 2012MY. My old 2011 LR4 (D4) had the same feature. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red) 𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone 𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone |
6th Sep 2024 3:27pm |
norland Member Since: 08 Feb 2023 Location: uk Posts: 26 |
Having to go into the car to switch on the hazard lights first, makes this feature just about useless. Might as well just open the rear door and use the buttons.
7th Sep 2024 10:26am |
you wouldn't want to open the rear door if you were hitching up. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
7th Sep 2024 10:02pm |
Or you're tight up against a wall. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
7th Sep 2024 11:00pm |
