![]() | Home > Td5 > Thoughts on TD5 Fuel Mileage |
revd Member Since: 20 Apr 2024 Location: England Posts: 236 ![]() ![]() |
33-34 mpg (UK) I drive like Miss Daisy - Premium diesel, 7.5 x 16 Michelin Latitude Cross tyres
works out at 28 mpg (US) |
CJs110 Member Since: 06 Sep 2023 Location: Windsor Posts: 22 ![]() ![]() ![]() |
So that does mean I have a big issue then
![]() Where to start diagnosing what could be affecting my MPG? If I could get it to 23 Mixed (US) would be plenty (I don't nesccarily drive like miss daisy lol) |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2733 ![]() ![]() |
Not necessarily no.
If you’re averaging 70mph that will have an impact. Try a journey cruising at 60mph and see how it does. |
My HT is lighter than SW and more aerodynamic than HCPU/DCPU, no a/c, chequer plate, roof rack/bull bar/spot lamps
All oils recently changed - including transmission oil/diff oil With the TD5 there is a sweet spot around 64-68 mph which I seldom venture beyond Last edited by revd on 30th Aug 2024 10:12pm. Edited 1 time in total |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2210 ![]() ![]() ![]() |
Mines heavy, lifted on 33s with a very large turbo. Averages about 19 - 23mpg (15 - 19US) around town. Around 26 - 28 (21 - 23) on long motorway runs
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 937 ![]() ![]() ![]() |
I am currently getting just over 30mpg with recent fill ups, that's lots of short local trips including some AC use.
A few longer summer trips thrown in has in the past seen this go up to 33/34mpg including AC use . This is in a pretty much standard 90 csw with michelin latitude cross 235/85/16 tyres. 2004 Defender 90 Td5 CSW 2002 Discovery 2 td5 GS (gone) 1994 Defender 90 300Tdi CSW (gone) |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 225 ![]() ![]() ![]() |
Is it an Auto or Manual? 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1235 ![]() ![]() ![]() |
Exactly despite the sleek and aerodynamic shape of the defender the difference between 60 and 70 mph could easily be a 50% increase in fuel consumption. If you want to go somewhere fast, in comfort and cheaply you have chosen the wrong car. |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 872 ![]() ![]() |
What sort of altitude and are you driving on level grades or up a lot of mountains? Is it an auto or manual. Also how are you working out your mpg? Might be worth double checking that too. Personally I’d say your numbers look a little on the low side, esp for a manual. But maybe not so far off if an auto. Might be worth doing say a 50 mile round trip and keeping the speed down a bit to see if it helps much. |
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 236 ![]() ![]() |
The key to good mpg is a light right foot, my 130 with a heavy camper conversion does 25mpg (UK) on a long motorway trip, but the key is I sit at 55 mph. If I go faster the fuel consumption increases dramatically.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
70 mph will defo affect your mileage. I get about 9-10 Litres per 100 kms cruising at 100 kph (that is about 30 mpg). Slow down to 60 (100kph) and you’ll see a big change in mileage. My experience is that the Td5 consumes huge amounts of diesel at high RPMs.
Try verifying at slower speeds and being gentle on the pedal, then you’ll know if you have an issue or not. Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
So I had a chance this morning to go on 57 mile highway loop. Topped up the tank before hand - started and ended at the same gas station.
My result was 19.8 MPG (US) @100 KMH (closest I can get to 60 MPH my speedo is in KM's). Mind you this is with just me - no real gear or tools just some spare fluid bottles etc in the rear. I don't think I passed a single car and I ramped up to speed at a fair pace (the ramp to the highway near me is actually a decline) For my previous run @70MPH where I got 17.5 that was primarily flat ground not sure the altitude above sea level. It is a manual 5spd. I understand the concept of faster = worse mpg because my Jeep which is also a box basically has the same phenomenon due to wind resistance. But I guess the question is for a mostly stock vehicle without a rack or heavy bumpers etc is the following make sense? @70 MPH --- 17.5 MPG (US) @60 MPH --- 19.8 MPG (US) Mixed driving as low as 30MPH as high as 70 MPH (for very short stints) --- 19-20 MPG (US) Is there anything else to check? |
So do you have black smoke at all while driving? What do you know about the ECU? As in do you have a tune in it? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 566 ![]() ![]() ![]() |
I have a 2005 90 XS on 265/75r16 BFG AT KO2’s it’s done 191000 miles and last week got 28.5 mpg (Uk)
That is with a mixture of towing motorways and country roads, all driven quite hard. It is tuned by Ian @IRB Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
