![]() | Home > Technical > Help with 200tdi clutch creaking |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 536 ![]() ![]() |
Dry clutch release arm pivot, or its pushing through the arm, I am assuming LT77 gear box
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 798 ![]() ![]() |
Thanks - yes it is the LT77.
How does one lubricate the release arm pivot? BORG - Bucks & Oxon 4x4 Response Group ![]() |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3473 ![]() ![]() ![]() |
Search in the forum for squeaky clutch pedal. Lots of info. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
I did have a search but the posts seem to be for Td5 and Pumas, unless you have found anything I haven't?
I am assuming the creaking is from the pedal box, which design is practically unaltered from 1970s (possibly even earlier) till 2016. There are many posts how to lubricate the pedal shafts.
If it is the fork, which frankly speaking I doubt as mine, when it punctured through, it went with absolutely no pre notice, it would be an engine or gearbox out. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4736 ![]() ![]() |
Pedal might just need a bit of oiling. 1982 88" 2.25 diesel
Unfortunately oiling the pedal did nothing and the noise is indeed from inside the bellhousing.
Time to get it booked in to a Land Rover specialist... BORG - Bucks & Oxon 4x4 Response Group ![]() |
Hoping it might be something simple! 1982 88" 2.25 diesel
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20591 ![]() ![]() |
Clutch fork perhaps, something that Pumas donโt have.
But isnโt the slave external to the trans on a TDI? Where as the Puma is internal, which is worse maintenance wise as the transmission needs to come out. But the clutch fork isnโt present, which is problematic. I am presuming the clutch fork is internal though on TDi Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
It is indeed internal. I will update the thread once the cause is know.
Some people change the fork for a stronger version. I never had bother with the standard version but some regard it as a weak link in the chain. 1982 88" 2.25 diesel
Iโve heard of that, Iโd assume that would be a good upgrade with a clutch change but not specifically on its own. Play Stupid Games, Win Stupid Prizes.
Mine already has a heavy duty one. Which if that is problem, doesn't inspire much confidence!
Having listened to your video the noise does seem pedal related, but maybe sitting in the cab allows you to place it differently 1982 88" 2.25 diesel
