Home > Puma (Tdci) > Metric or Imperial
hebdenap1@aol.com
Metric or Imperial
I want to order a rear suspension bolt kit for my 2013 110 and there are two options :-
One for vehicles up to 9A768936 (imperial A frame bolts) and one from 9A768936 (metric A frame bolts)
I don’t know what these serial numbers refer to as it is not the VIN. Can any one advise?
I assume that being a later vehicle it will be the latter be we now what assumptions do…….
Post #1042603 12th Aug 2024 7:24pm
ickle
I think those are the last digits of the VIN
Fairly confident they'll be metric.........
Post #1042606 12th Aug 2024 7:38pm
Are the A-frame brackets bolted to the cross member (imperial) or welded (metric)?
Post #1042609 12th Aug 2024 7:56pm
hebdenap1@aol.com
My VIN is 429899 so no where near the range mentioned and I’m sure that greater than 300,000 more Defenders were built in the last 3 years Smile
I check the mounting bracket
Post #1042616 12th Aug 2024 8:43pm
Martin
Site Admin
2013 will be the metric type.
Your VIN will actually end DA429899, and for this purpose "DA" is after "9A".  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1042617 12th Aug 2024 8:45pm
I think mine was metric, as far as I remember. (Cannot be 100%).
I think Gwyn Lewis does bolt kits as well for that. TheThunder Rolls🇬🇧🇺🇸
Post #1042655 13th Aug 2024 12:15pm
