Home > Puma (Tdci) > Reverse vibrations
Page 4 of 4 <1234
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Sorry should of been more clearer, hoping to get time to do more testing now I found out it does not look to vibrate in low gear but want to try diff lock combinations, that may involve props off again etc, the special tool arrived yesterday so should make it simper than the two spanners I was struggling with. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #1042178 8th Aug 2024 2:46am
Caterham
I had similar symptoms - it was related to the transfer box being locked (but I was unawre of being locked).
daft as it sounds - reverse up hill and if the problem exists - try lifting wheel(s) off ground using trolley jack and try again Smile
Post #1042223 8th Aug 2024 12:11pm
It’s surprising how often the transfer box can accidentally diff lock or slip out of low or high range.
I personally prefer to change between high and low stationary or ever so slightly rolling definitely not over 5mph.
If you have the diff locked you should have the dash light illuminated, if no then it’s not working.
I’ve had it in high before, but not quite been fully in and you can be driving along and total loss of drive.
Fully engaged into high again and all sorted out, but can really make you think if you didn’t realise it was that.
You should used the low box and diff lock occasionally or it will get seized up, and also the linage needs to be lubed, rarely but still needs to be kept lubed.
A once it a blue moon job but really helps, a nice thick grease works well as it has to last. TheThunder Rolls🇬🇧🇺🇸
Post #1042226 8th Aug 2024 1:00pm
Caterham
and there lies the problem - diff lock was engaging without the lock light.
if I were to manually put it into lock - hey presto the light works. Neutral
Post #1042233 8th Aug 2024 2:09pm
Race.it
So from what I know by messing the diff lock and high/low are manual leavers, only the light is electronic part.
So which is which on the transfer case? Is it possible to reach over and manually disconnect the leaver and set into position (to test) or not possible? Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #1042236 8th Aug 2024 2:20pm
Caterham
hi Race.it,
not sure if I fully understand your question(?).
from underneath / but on top of the transfer box there is something similar to a circlip. once removed the lever linkage can be detached from the tranferbox allowing you to manually from underneath more into / out of diff lock. this should enable testing of the diff lock light. Thumbs Up
Post #1042291 9th Aug 2024 8:42am
Race.it
So after I typed that I found a picture online
Basically I am wondering if when I put in low range for the test the other day diff lock engaged and all was fine in low but high diff lock was off and vibrating.
Thanks for the reply. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #1042292 9th Aug 2024 8:45am
Page 4 of 4 <1234
