Home > Puma (Tdci) > Reverse vibrations
Page 1 of 4 1234>
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Reverse vibrations
So, yet again the gift that keeps giving is confusing me again.
So if I let the 110 roll backwards down a hill no vibrations
If I try to reverse up a hill I get a vibration like the handbrake or another thing is catching.
Noticed it first when reversing and turning but now looks to be any reverse up a hill. Reversing down (with power engaged) feels fine.
Was thinking handbrake drum but rolling back is fine (clutch dipped) so now thinking more it’s clutch.
Before I go an rip out clutch and find it’s not that, anybody else suffered the same symptoms?
I did try to film it underneath when it’s vibrating but all I see is gearbox/transfer case moving on its mount, could it be just the mounts? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #1039098 4th Jul 2024 6:27am
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
It may be worth checking the position of your exhaust. After fitting mine it needed a slight adjustment as was rubbing when in reverse. WARNING.
This post may contain sarcasm.
Post #1039101 4th Jul 2024 7:00am
landy andy
No lockers or lsd s on it?
Post #1039104 4th Jul 2024 7:34am
Race.it
It feels more than just the exhaust, it’s nochy and banging when reversing.
No lsd’s or lockers that I know of.
I do have a new transfer case to fit, as I have a leak on the center shaft and it was simper to get one that’s fixed (the re bushing) than try to remove mine and get it locally machined. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #1039110 4th Jul 2024 8:33am
Dinnu
Clutch does not know if you are moving forward or backwards.
I would remove a prop shaft at a time, test in diff lock, and see if it goes away. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1039114 4th Jul 2024 8:58am
Race.it
Yep I could not work out why it could be clutch. But feeling was something when powered as when freewheeling it was not vibrating Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #1039117 4th Jul 2024 9:17am
Probably exhaust or prop UJ. TheThunder Rolls🇬🇧🇺🇸
Post #1039144 4th Jul 2024 3:11pm
jst
It's not the clutch.
Check transmission mounts, torque on the box can move it to knock on something. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1039151 4th Jul 2024 5:15pm
Race.it
Will be checking mounts and props this weekend.
The whole car vibrates when reversing and clunks it’s not like a exhaust banging you can feel the car bumping around hence I thought handbrake but when not under power going reverse down a hill does not do it Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #1039159 4th Jul 2024 6:02pm
It could be dirt in the handbrake drum causing imbalance or it may have been bashed if there is any signs of that?
The UJ’s can be a bit difficult to check without taking off one end, might just be a single bearing.
Do you have a go pro camera or anything like that? If so you might able to look for anything visual if there is any signs if you can mount or strap it somewhere.
Worth checking rear dampers and A frame too.
Good luck. Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #1039161 4th Jul 2024 6:14pm
Race.it
I put my iPhone under the 110 and recorded, all I see is the transfer case/gearbox moving a lot when in reverse, going forward it was not moving around as much, hence my assumption it was in that area, but it could be props binding etc or even further down, so ill investigate that this weekend. Thanks for the reply and hints so far. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #1039176 5th Jul 2024 6:42am
Have you tried this yet?
Post #1039177 5th Jul 2024 7:08am
Race.it
That is this weekends task 😱.
Don’t use the 110 every day and time constraints means play time is only at weekends unless something catastrophically failed that needs immediate attention.
First thing I will try will be props off individually.
I assume both props connected vibration present
If I remove front or rear and vibration stops then issue is prop or diff connected to that prop. If both props off in turn (as both off at the same time won’t help me go anywhere 😂) keep the vibration then issue in gearbox / transfer case side
Well that’s my thinking. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #1039180 5th Jul 2024 7:30am
Make sure you keep the handbrake drum on if you take the rear prop off or you’ll have no hand brake. TheThunder Rolls🇬🇧🇺🇸
Post #1039182 5th Jul 2024 7:33am
Dinnu
From your description I doubt id having both props off will give you any vibration/conclusion as it seems to happen only when there is a load (does not happen reversing down a hill). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1039183 5th Jul 2024 7:37am
Page 1 of 4 1234>
