![]() | Home > Td5 > TD5 running issue |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 874 ![]() ![]() ![]() |
Hi
Just off the top of my head... What's the coolant level like? are you having to top it up? Have you pulled the red connector off the ECU under the drivers seat and checked it for oil? Not sure how long you have had your Landy but if it has stood for a long while it could possibly be bad/contaminated fuel? How many miles? It could be that the injectors need to be cleaned and refurbished? Jim |
Taz1153 Member Since: 04 Aug 2024 Location: Midlands Posts: 6 ![]() ![]() ![]() |
Thank you for your reply. I really appreciate it. The coolant level is ok, injector harness changed this year with no signs of an oily loom, she does a tank of fuel every few weeks, she’s had a new fuel pump last year. Serviced each year with all filters changed. I fear injectors or even worse, head compression. She’s just had a new MAF sensor. I’ve cleaned the MAP sensor.
To be honest Taz changing the injectors is not that hard a job.
There’s a set of 5 from a Defender TD5 with 115k on the clock for £100 over on EBay. You could take a chance and just clean them and fit them and see if that improves anything? Jim |
Cheers Jim. Annoyingly my injectors are only at 90k miles. I suspect that will be the taken path. In my head these issues have only starred since the MAF sensor was changed. It makes no sense but is at the back of my mind.
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 542 ![]() ![]() |
What make MAF did you fit, genuine or seimens only. Try disconnecting MAF does it run any better?
I didn’t change the MAF sensor. I took out the original which has Bosch written on it. It wasn’t very dirt but cleaned it with brake cleaner and popped it back in. You think it might be broken anyway?
I’ll disconnect it tomorrow and see what happens
On the off chance someone is still looking at this thread, the truck went to a local garage and didn’t show the failure/problem. They could not find a fault with it. I took it home and typically it failed the next day. It’s been back since and had its injectors refurbed and refitted on new genuine seals. It runs like a dream. The place injector in Shrewsbury said all the injectors were at the point of complete failure. I’ll take that with a pinch of salt but it’s looking like they were the fault, at the moment at least. Thanks again for your help.
Glad that you got it sorted
![]() Jim |
