![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1429 ![]() ![]() ![]() |
No they are only fitted if you specified them on your original order. They are brilliant though
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
The_75th Member Since: 28 Apr 2023 Location: Devon Posts: 31 ![]() ![]() |
Tried this one - no change that I could see. |
takuyaf Member Since: 09 Sep 2023 Location: Tokyo Posts: 1 ![]() ![]() |
Does anyone know the difference between 4.00 build 98 and 4.00 build 131?
awktm Member Since: 19 Jun 2024 Location: Melbourne Posts: 14 ![]() ![]() |
How did you access the beta versions?
mohd Member Since: 13 Jun 2024 Location: uae Posts: 9 ![]() ![]() |
Hello, does anyone know how to activate the traffic sign recognition?
i changed this to fitted but no luck MultiCAN-742 Traffic Sign Recognition TSR TSR Not Fitted |
emariu Member Since: 12 Jun 2023 Location: Calarasi Posts: 12 ![]() ![]() |
I wanted more accurate speed readings on board speedometer(mine was about gps read speed - 4km/h) with:
MultiCAN-838 from: Speedo market 0- 3.5% + 2kph To Speedo market 1- 2.0% + 0kph Now my speed is spot on with GPS readings.. BUT when I set my speed on ACC it only goes to the set speed minus 4 km/h How to adjust also the ACC set speed to the correct value? Thanks for helping |
Dannymm Member Since: 28 Jun 2024 Location: Wiltshire Posts: 18 ![]() ![]() |
You need to also adjust the following to match
MultiCAN-577 SpdoCalPercentScale 3.5% Scaling MultiCAN-575 SpdoCalkmhOffset + 2.0 km/h |
Thank you!
Thanks! |
Any further thoughts on this? Is there possibly missing hardware?
Thanks ![]() ![]()
I tried several modifications to these settings, but I am getting a lot of errors (ABS,Emergency braking,DADC etc. ) which cannot be cleared. Now my ACC doesn't even work.. Do you know what values are OK for not getting errors but still calibrate ACC speed setting? Thanks |
These are the values I used without any errors
MultiCAN-577 SpdoCalPercentScale 3.5% Scaling was the default Changed to 2% MultiCAN-575 SpdoCalkmhOffset + 2.0 km/h was the default Changed to + 0.0 km/h |
Now it's working as it should
Thanks again ! |
RoysRover Member Since: 04 Aug 2024 Location: Pennsylvania Posts: 2 ![]() ![]() |
I saw in a previous post that boosting the cell signal was an option. Has anyone figured out how? Thank you!
