Home > Puma (Tdci) > Reverse vibrations |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 823 |
It still vibrates going down a hill in reverse in gear if but not as much as gravity helps.
I think the load is the key part. Thanks re the handbrake I’ll remember to bolt it back on when I remove the rear shaft Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
5th Jul 2024 7:46am |
I have not removed anything yet, working on it mid week is next to impossible, I could do the video part, but rest has to wait till the weekend.
Also need to record going forward. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
5th Jul 2024 11:40am |
Sorry for the late reply family things happened then got some bad virus.
So this morning the task was to isolate where my issue was, by following the good people’s of the forum advice So before we start thought good idea to ensure it’s still happening. Yep it is, set myself on a small incline and in reverse checks to see if it’s vibrating. So pull into the garage to check propshafts and remove them one by one to see if I could identify the issue. https://youtube.com/shorts/bNzVyCU0JtU?feature=share So I guess this is probibly my issue. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
28th Jul 2024 9:45am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5724 |
Yep. That will be it.
28th Jul 2024 9:48am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20432 |
Pinion nut is loose I’d say with that, and probably needs a new seal as well as it’s probably elliptical rather than circular.
Is there any diff oil leaks? Also, be sure to check the UJ nearest the pinion where that is on that end of the prop, that was what I had. Failed UJ bearing, the roller bearings had gone in a single cup, that then caused he issue with the pinion and oil leak. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
28th Jul 2024 12:03pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3419 |
That has some play, most likely a loose nut. But the spindles are generally quite a good fit, so I hope you have not damaged the transfer case front output shaft.
I believe that LandRover glued the output flanges onto the splines at the factory. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
28th Jul 2024 4:56pm |
I have a brand new transfer case (well Winchester gears one) to go in, due to leaks on the intermediate shaft (could not find anybody local to machine the case if I removed it to get the inset put in). so bit the bullet and got a new TC brought a few months ago.
This could just mean it has to go in now. Yep ill check the UJ's on all the props whilst off Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
29th Jul 2024 8:31am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8049 |
Did that not vibrate under any load fwd or reverse?
If t box is still rotating under reverse I would be checking drovers side mounting. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
30th Jul 2024 4:30pm |
I have both mountings to change brought them in anticipation from lof when I brought a set of brake disks / pads (that I still need to change).
Only vibrates so you could notice when reversing under load (incline) Going forward no vibration, though if you free wheeled down a hill then added slight load there was a noise but holding the high/low lever removed the noise. I’ll look at this item first then get to the next item, like they say making mechanics out of normal drivers 😂 Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
30th Jul 2024 9:14pm |
Yes, it won’t be long before something else will need fixing! Though hopefully long enough. $W33T $0U7H3RN $UG4R
30th Jul 2024 10:14pm |
Yep you can here it ploting what it will throw out next. Searching for my first Defender...and started just as Covid hit, so talk about timing.
31st Jul 2024 5:09am |
So front prop got removed today, that’s an interesting job. Thinking of leaving it rear wheel drive 😂😂
So the nut was loose, 30mm socket tightened it up, lot looked at the torque for it yet, Don’t know if they have a lock washer on it, but it was not bent over if it has one. Debate now is do I go all in and change the transfer case, or just tighten the nut to correct torque and put front prop on, or replace the whole case (it leaks, thought it was on the intermediate shaft as lots of sealent around that, but could if been the front prop shaft flange all the time prop shaft feels ok on the UJ’s will prob clean that up and re grease anyhow. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
3rd Aug 2024 5:25pm |
If output nut is loose it will leak there.
Front prop isint hard to remove and job made easier with propshaft tool. Just a nylon no locking tab. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
3rd Aug 2024 8:59pm |
First propshaft tool fell out of packaging and I received a empty envelope
Second try has been stuck in customs for over a week now Going to do up the nut to torque think it’s 168nm or something close to that then see if my vibration in reverse has gone I lead such a exciting life Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
3rd Aug 2024 11:01pm |
