Home > Puma (Tdci) > Wet right foot |
david110 Member Since: 11 Dec 2009 Location: Stirlingshire Posts: 81 |
Just checked my car tonight same thing but from the accelerator peddle area. car has not moved for two days.
2nd Dec 2011 9:29pm |
Snowbeast17 Member Since: 20 Nov 2011 Location: Highlands Posts: 48 |
Yes around that same area. Brilliant we will go out one day in heavy rain, open the door and get soaked when we open the drivers door RRS tdv8 08
Disco 3 HSE 57 Defender 90 xs 06 All gone |
2nd Dec 2011 9:32pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
must be a Scottish thing oh no wait i have the same problem
2nd Dec 2011 9:34pm |
So where's the leak ? RRS tdv8 08
2nd Dec 2011 9:36pm |
i had it dripping down onto my accelerator my door seal didnt look like it was sitting right got some dum dum like silicon on it put it in the top corner of the door were the seal goes, so far so good its rained today and is as dry as a bone try that
2nd Dec 2011 9:39pm |
Ok, I'll give that a go and see if that will fix it. I did wonder if it was coming through the door seal. RRS tdv8 08
2nd Dec 2011 9:44pm |
yer mine looked like it was coming through the bulkhead at first but figured it must have run down along the bulkhead and dripping from behind the dash
2nd Dec 2011 9:47pm |
I hope its not coming through the bulkhead on mine . I'm sure it will be something quite simple RRS tdv8 08
2nd Dec 2011 9:51pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Got the T shirt for this one
Dealer replaced the rubber seal between the windscreen frame and bulkhead - 60% fixed - they also fixed the rust on the inner bulkhead that this leak had caused I sealed the windscreen after I had a cracked screen replaced and saw the amount of water sitting in the lower windscreen channel (it had not been raining for days if not weeks) - 90% fixed. Hopefully final fix done on Wednesday. I couldn't work out why I was still getting puddles on the front mats when the vehicle was parked and it had been raining. By pure chance on Wednesday I had the drivers door open whilst doing another job and I noticed a pool of water appearing on the mat. The front door seals have an outer and inner circular section. The door inner section on the drivers side finished about 1/4" above the floor and water was running out of the seal onto the mat. Dum Dum to the rescue and after heavy rain Thursday no more puddles Two new front door seals are on the shopping list, I should get them fitted under warranty but will do the job myself as at least I know it will be done properly. Bob |
2nd Dec 2011 9:56pm |
dum dum for the win
2nd Dec 2011 9:58pm |
Oh Jesus! I only bought it two weeks today and it's split new. RRS tdv8 08
2nd Dec 2011 9:59pm |
Yes!!! http://www.defender2.net/forum/topic2126.html?highlight=seal Taken from same thread and 'own experience' of this problem... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
2nd Dec 2011 10:08pm |
What K9F said ^^^^
Get the windscreen sealed first - everything looks like it is a tight fit but water gets behind the screen onto the bulkhead and down into a channel that runs under the dash and finishes above the pedals on the drivers side and about in the centre of the passenger footwell. Either get a tube of black windscreen sealer (don't use silicon) and do it yourself or go to a windscreen company and get them to do it - should not cost a lot. Bob Last edited by bob neville on 2nd Dec 2011 10:14pm. Edited 1 time in total |
2nd Dec 2011 10:11pm |
Bob's right too...
From same thread link on previous post....
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 2nd Dec 2011 10:15pm. Edited 1 time in total |
2nd Dec 2011 10:13pm |
