Home > Puma (Tdci) > Wet right foot |
Snowbeast17 Member Since: 20 Nov 2011 Location: Highlands Posts: 48 |
Thanks guys I'll take a look at that RRS tdv8 08
Disco 3 HSE 57 Defender 90 xs 06 All gone |
2nd Dec 2011 9:14pm |
Autoglass sorted mine in an hour after months of woe! No leaks since! If you go through life with your head in the sand....all people will see is an ar5e!!
2nd Dec 2011 9:18pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
They should but I would trust somebody like Autoglass to do in properly first time.
It is not difficult to do yourself, worst part is getting the excess sealer off the paintwork. This is the sealer I used. http://www.directcarparts.co.uk/product/27...black.html Bob |
2nd Dec 2011 9:53pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
I've had the same leak from day one after heavy rain. In fact I have removed the metal strips that hold the sound deadening to the side of the bulkhead by the doors so I can dry them out more easily.
I always thought that it was coming in through the draught strip thing at the corner where the screen hinge is because I can see it dripping from an adjoining metal bracket which is held on by two bolts (inside the vehicle). I put it down to bad design - the fix being to cut out enough of the strip in order to completely seal the gap properly from side to side - when the weather is dry enough ! But now I'm not sure as the windscreen seems to be just as likely a culprit. But if you put a load of sealant in there wouldn't it simply trap any water that might be already in there and will eventually rust its way through ? |
2nd Dec 2011 10:40pm |
Due to the high risk of damaging the screen on removal dealers can be reluctant to remove the screen and will only do so as a last resort. I stumbled across the cause due to Autoglass replacing my screen due to a stone crack. Funny how Autoglass claimed they knew about the water ingress issue on Pumas when the dealers don't/didn't! Irrespective of this if you have no joy with the dealer take it to a 'glass specialist' who carry out screen removals on a daily basis and get them to clean and seal it, it will save you going round in circles getting nowhere fast with the dealer if they don't play ball. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
2nd Dec 2011 10:44pm |
david110 Member Since: 11 Dec 2009 Location: Stirlingshire Posts: 81 |
Problem sorted, just got my car back from the dealer, the windscreen had been leaking into the bulk head, dry feet
5th Dec 2011 5:07pm |
Good news! Hopefully Snowbeast will have the same result! If you go through life with your head in the sand....all people will see is an ar5e!!
5th Dec 2011 7:31pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Mal, was right...Its the leaking windscreen NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
6th Dec 2011 12:38am |
