![]() | Home > Puma (Tdci) > 2007 Puma Central Locking and remote fob battery change |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17620 ![]() ![]() ![]() |
I am unfamiliar with a CR1220.battery but do know that my 2007 fobs use a CR2032. Could the wrong battery be the problem?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20650 ![]() ![]() |
As Blackwolf mentioned, be sure to have the correct battery.
Also to sync, press lock or u lock multiple times rapidly with doors shut until indicators flash and red dash light flashes at a rapid rate, once the red dash light flash rate slows to the normal slow rate when locked you can use the fob like normal. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2167 ![]() ![]() |
The cr1220 is too small and will be rattling around in fob. As highlighted above fit the correct cr2032. Ideally a genuine Panasonic or Varta from a reputable source.
ASBGuernsey Member Since: 14 Jul 2024 Location: Guernsey Posts: 10 ![]() ![]() ![]() |
Mystery solved - I have 2 remote fobs. One uses the CR2032 and one uses the CR1220 - it appears to be an "Xpart" replacement board, and can only fit a CR1220. The CR1220 requirement in this second remote is the only battery that will fit in the holder, and the writing on the PC Board also advises to only use a CR1220. The one using a CR2032 appears to be original to the vehicle.
My main question was how to register the fob with the alarm and locking module, and Custom 90's answer helped me to do so. After some button clicking, it seems to work again. After changing the fob battery, the car was all over the place. Sometimes it would not start, other times it would. Now I just need to sort out the aftermarket electric window lifts ! I have the replacement 5 pole switches from Paul Mc, and hopefully this will sort it out. I will also check all the fuses under the RH seat, to ensure those are all in good shape. The window issues started after I saw smoke coming out of the dashboard when the driver window switch was activating to open or close the windows. |
