Home > Faults & Fixes (L663) > Original D240 AdBlue injection timing fault from factory
Tussockland
New Zealand
Hi, First post here.
I've been looking to buy a Defender D240, and currently made an offer on a 2020 one that's had it's engine replaced at 40,000km (now got 80,000km).
Out of the approx 20 i've looked at so far, I've found two of these state they have had engine replaced. One at 40,000km and one at 70,000km.
One owner says: The D240 Engines (In a range of models) had a fault with the Ad blue injection timing. This was fixed in an update, but some damage was done to the engine prior to the update.
Other says: The original calibration of the 240D engine injected too much AdBlue and if they didn't update the calibration before 10,000km it results in damage.
(and this is a tech guy who runs a High Performance car business, so should be in the know)
Both were fixed under warranty, and calibration was updated.
Now I can't seem to find any info about this online, and it seems a major issue that some may not even know about ... !
Have i missed something searching the net (and this forum)?
Post #1040881 24th Jul 2024 10:36am
eno
Australia
That seems a bit strange as AdBlue is injected into the exhaust system, after the engine, in order to reduce NOx emissions. So problems in the AdBlue system shouldn't be damaging the engine.
Post #1040884 24th Jul 2024 11:07am
Tussockland
New Zealand
You know, that was what i originally thought, but i was then thinking maybe i'm no expert, lol.
But i did read somewhere how the blocking of exhaust/DPF/CATconverter "type" stuff can damage the engine... but i have no idea what has happened here, only what they said (likely from the dealer).
So to be clear, they do not say injection INTO the engine...
And that may be why one said it can damage the engine after 10,000km if calibration was not updated, meaning possible build-up somewhere in the exhuast.
Post #1040885 24th Jul 2024 11:12am
Defendit..
Netherlands
Stay away from the first 2.0 diesel four bangers. Go for a newer six
The 2.0 Petrol is fine and fast No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1040886 24th Jul 2024 11:37am
lightning
There were issues with oil dilution on the 2.0 lngenium, caused by incomplete DPF regeneration
Go for a 3.0 litre. No such issues with that engine. lt's a better unit as well, being a 3.0 litre six cylinder and more suited to the Defender.
Post #1040891 24th Jul 2024 12:32pm
Moo
Ukraine
Forget the D240 of derivatives of it. They have a habit of throwing timing chains and oil dilution issues. I managed to catch it before it went on my daughter’s Discovery Sport. My neighbour lost his engine because of it just out of warranty on his Evoke. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1040897 24th Jul 2024 1:12pm
Tussockland
New Zealand
Thanks you guys, your putting me off fast!! lol. I'll might just keep searching for those other models...
Post #1040931 25th Jul 2024 1:38am
lightning
Land Rover stopped using the 2.0 liter in 2021 in the Defender.
Post #1040941 25th Jul 2024 7:14am
Moo
Ukraine
The 3.0l six is a cracking engine. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1040948 25th Jul 2024 8:10am
Gareth
The 3.0 I6 is proving reliable for me at least. Mine is an early 2021 70 reg, and was one of the very first 3.0 I6 diesel engines. Now on 29k and only engine related issues were recalls for exhaust bolts and auxiliary belt pulley.
I have seen a few posts around FB and the like saying there have been loads of failures of new Defenders, but I think they are just scaremongering. I’ve not heard of anyone with an I6 having a major failure requiring an engine swap.
Or am I wrong? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #1040959 25th Jul 2024 10:43am
Retroanaconda
I’ve got a late-2020 D200 3.0 litre on 86k miles and would agree it’s a great engine.
I’ve not heard of any catastrophic failures either. Mine has only needed a sensor in that time and regular servicing (every 10k miles).
Post #1040963 25th Jul 2024 12:32pm
zilch
Australia
Assume you are having a check on the carsales.com.au website ? I would agree with what is being said
in the thread, avoid the 2.0 4 cylinder diesels, especially if you are heading out into the wilds, go with the 6 cylinder in D250 or D300 format .. or if a Petrol floats your boat the P400 6 cylinder.. If you are on Facebook there are a couple of Australian New defender owners groups who can advise in terms of set
up for the Australian environment…. Cheers Jim yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #1041008 26th Jul 2024 5:21am
Tussockland
New Zealand
My wife wishes we were in Aus! She loves the heat. I'm in NZ, and not a lot of options here yet.
Post #1041080 26th Jul 2024 8:14pm
