Home > Faults & Fixes (L663) > Original D240 AdBlue injection timing fault from factory |
eno Member Since: 15 Apr 2024 Location: Qld Posts: 25 |
That seems a bit strange as AdBlue is injected into the exhaust system, after the engine, in order to reduce NOx emissions. So problems in the AdBlue system shouldn't be damaging the engine.
24th Jul 2024 11:07am |
Tussockland Member Since: 24 Jul 2024 Location: Southland Posts: 4 |
You know, that was what i originally thought, but i was then thinking maybe i'm no expert, lol.
But i did read somewhere how the blocking of exhaust/DPF/CATconverter "type" stuff can damage the engine... but i have no idea what has happened here, only what they said (likely from the dealer). So to be clear, they do not say injection INTO the engine... And that may be why one said it can damage the engine after 10,000km if calibration was not updated, meaning possible build-up somewhere in the exhuast. |
24th Jul 2024 11:12am |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 421 |
Stay away from the first 2.0 diesel four bangers. Go for a newer six
The 2.0 Petrol is fine and fast No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
24th Jul 2024 11:37am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2734 |
There were issues with oil dilution on the 2.0 lngenium, caused by incomplete DPF regeneration
Go for a 3.0 litre. No such issues with that engine. lt's a better unit as well, being a 3.0 litre six cylinder and more suited to the Defender. |
24th Jul 2024 12:32pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1352 |
Forget the D240 of derivatives of it. They have a habit of throwing timing chains and oil dilution issues. I managed to catch it before it went on my daughter’s Discovery Sport. My neighbour lost his engine because of it just out of warranty on his Evoke. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
24th Jul 2024 1:12pm |
Thanks you guys, your putting me off fast!! lol. I'll might just keep searching for those other models...
25th Jul 2024 1:38am |
Land Rover stopped using the 2.0 liter in 2021 in the Defender.
25th Jul 2024 7:14am |
The 3.0l six is a cracking engine. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
25th Jul 2024 8:10am |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1097 |
The 3.0 I6 is proving reliable for me at least. Mine is an early 2021 70 reg, and was one of the very first 3.0 I6 diesel engines. Now on 29k and only engine related issues were recalls for exhaust bolts and auxiliary belt pulley.
I have seen a few posts around FB and the like saying there have been loads of failures of new Defenders, but I think they are just scaremongering. I’ve not heard of anyone with an I6 having a major failure requiring an engine swap. Or am I wrong? 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
25th Jul 2024 10:43am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2637 |
I’ve got a late-2020 D200 3.0 litre on 86k miles and would agree it’s a great engine.
I’ve not heard of any catastrophic failures either. Mine has only needed a sensor in that time and regular servicing (every 10k miles). |
25th Jul 2024 12:32pm |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 815 |
Assume you are having a check on the carsales.com.au website ? I would agree with what is being said in the thread, avoid the 2.0 4 cylinder diesels, especially if you are heading out into the wilds, go with the 6 cylinder in D250 or D300 format .. or if a Petrol floats your boat the P400 6 cylinder.. If you are on Facebook there are a couple of Australian New defender owners groups who can advise in terms of set up for the Australian environment…. Cheers Jim yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
26th Jul 2024 5:21am |
My wife wishes we were in Aus! She loves the heat. I'm in NZ, and not a lot of options here yet.
26th Jul 2024 8:14pm |
