Home > Maintenance & Modifications > Nugget replacement air filter cartridge |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3156 |
I’ve never had an issue finding filters either, I think my last batch came from Eurocarparts. Also for those wanting a washable lifetime filter, I spoke with ITG a while back who offered to make some to fit. WARNING. This post may contain sarcasm. |
11th Mar 2024 6:18pm |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 406 |
I know this is a nugget thread but the Ali sport filter is been mentioned a bit as well and my bits have arrived.. They have made a few tweeks I believe and I asked them to send me a cleanable filter.. Is it ITG??.. It comes with a standard paper element type filter..
I'll not be fitting it for a few weeks but if there is anything worth talking about I'll get back when I do fit it.. Picture of the bits👍 Click image to enlarge Edit.. Should mention I got the low level intake version as I have a vacuum tank for the red boost on the wing top so my intake will follow the route of the standard defender plastic pipework |
12th Mar 2024 6:32pm |
There is an Allisport filter thread on here somewhere but; no it’s all very straight forward to fit. The ITG filter looks nice but you won’t notice any difference to the yellow paper one. I keep the paper one for when the ITG is drying out after washing. WARNING.
12th Mar 2024 6:46pm |
I'm not sure in the scheme of things what to expect with this but it's a far neater and simpler set up than standard, and just like the disc conversion on the habdbrake appealed to me so did this type of intake compared to standard.. If it makes access by removal simpler and quicker and gaurentees a sealed inlet that will be good
If there is to be any increase in power /torque it surley has to be because of an increased air flow capacity that the engine can use and that I can check with a scope.. I already have stored traces in its present set up, so I'll see what this set up comes up with at some point👍 |
12th Mar 2024 8:30pm |
I noticed a small but definite increase in performance with both Nuggetstuff and Allisport over stock and also over modified stock airbox. I couldn’t tell any performance difference between Nuggetstuff and Allisport, however they both have distinct intake sounds. I had been meaning to stick them on the dyno but never got around to it. It will be interesting to see your results. WARNING.
12th Mar 2024 10:47pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4149 |
For those using the Mahle LX830...
My Nugget airbox has the vacuum gauge to warn you when the filter needs changing. With the original filter I never had any warning from the gauge even when filter was quite old. With the Mahle the gauge warning is triggered by any sort of high engine load situation even with a brand new filter. Although I can't feel any lack of power, it concerns me that the Mahle might not be flowing enough air. It is a slightly larger diameter filter than the original, so there is less room around the outside, could that be the issue? I have another filter with the same external dims as the original which I'm going to try. 2007 110 TDCi Station Wagon XS |
22nd Jul 2024 7:55pm |
Jimbob292 Member Since: 06 Nov 2023 Location: Derby Posts: 19 |
Yes i had the same issues with the Mahle type, it just didn't fit flush, it was a to get the top housing to close.
I could get the little red signal to come on, without any serious peddle to the floor. I've gone back to the original Western Filter, it was expensive, but at least my economy has returned, with the Mahle it dropped right of the scale. Click image to enlarge |
23rd Jul 2024 6:31pm |
I'm trying an Alco MD106 now, which is dimensionally the same as the Wesfil one except for the small hole in the base and lack of a sealing gasket. I've made my own out of neoprene. Unfortunately testing is stalled pending replacement of my knackered clutch. 2007 110 TDCi Station Wagon XS
23rd Jul 2024 8:10pm |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 |
Hey Jimbob - where did you get the Wesfil filter from? I'm not been able to find one here in the UK. I've been making neoprene 'spacers' to make the Mahle filter fit but its not the best solution. |
24th Jul 2024 10:57am |
I bought it from 4x4 overland, i know its not cheap, but it works and i don't have any issues.
https://www.4x4overlander.com/product/nugg...nd-gasket/ |
24th Jul 2024 12:52pm |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 204 |
Cheaper to buy from Aus including shipping to UK.
For example: cj-motor.com (currently in stock and ship internationally) for a single filter shipped to UK is AU$90 which currently is 46 pounds. Buy 2 and it falls to approx 37 pounds each, buy 10 and its 27 pounds each. No affiliation to these guys and never bought from them myself, just an example as an alternative to 65quid each. |
24th Jul 2024 1:53pm |
Thanks piechipsandpeas. This is a great idea.
If they are happy to ship to the UK and there is enough interest I might buy a batch of them. I'll be going to the LRO show and could meet folks there. Let me know if anyone else is interested. Click image to enlarge It looks like 10 filters would be about $540 AUD - around £275. |
29th Jul 2024 11:05am |
Early conclusions are that the Alco MD106 is the best alternative filter for me. Is cheap and available in the UK. It has the same dims as the Wesfil, but is missing the foam sealing tape on the top. You can buy a roll of said tape for not much money on Ebay.
I did some 4th gear full throttle up hill pulls to put some load on the turbo. In a stock Puma, this is much less exciting than it sounds! However, the important thing is that this didn't cause the red filter blocked warning to come on (unlike the Mahle/Knecht LX830. 2007 110 TDCi Station Wagon XS |
3rd Aug 2024 6:55pm |
Hi Bluest - thanks for the tip.
Could you let me know where you bought the Alco MD106? I cannot find it in stock anywhere. Do you have a link I could use? Thanks |
3rd Aug 2024 9:15pm |
