![]() | Home > Td5 > Changed transfer box to 1.2 and cruise control doesn’t wor |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6661 ![]() ![]() ![]() |
https://www.defender2.net/forum/search.php...edo+healer
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2321 ![]() ![]() ![]() |
It can be done in the ECU too, negating the need for a speedo healer.
phillips321 Member Since: 16 Dec 2021 Location: UK Posts: 103 ![]() ![]() |
Been quoted £130+VAT For the ECU mod but I can get a speedo healer for £85ish
If I go the healer route I assume I put it between speedo and ECU? If so I’ll mount it behind the speedo cluster. Anyone know the correct cable I need to put it between? |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 723 ![]() ![]() ![]() |
I had a similar issue on my TD5, after installing a recon gearbox with the V8 5th gear ratio.
The pulse signal goes from the sender on T-box to speedo gauge where it is multiplied by 2 and sent down to the ECU. In my case, the altered 5th ratio sent a false signal which tells the ECU to cancel the CC due to the signals being out of the parameters. The speedo read accurately and I didn't want to change that so I installed the unit between the instrument cluster and the ECU near to the main black ECU plug. In this case the red cable on the Speedohealer needs an ignition live, the black cable needs an earth. Cut the yellow/white ECU wire coming from terminal B13 on the black ECU plug, connected the white wire to the speedo gauge end and the green wire to the ECU end. 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Thanks for this.
Any idea if that yellow/white cable goes behind the instrument cluster to the speedo? |
It's yellow+pink, and is on one of the pink plugs to the speedo.
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 565 ![]() ![]() ![]() |
I put my speedo healer with the engine ecu, I have on overdrive so fitted a 5pin relay to switch the speed signal going direct to the ecu or via the speedo healer.
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 511 ![]() ![]() |
I wouldn't put the healer on the speedo feed as your speedo will read slow I better to connect it at the ECU speed input .
The yellow/pink is the signal OUT of the speedo, to the ECU.
mturri Member Since: 13 Jul 2010 Location: All over Posts: 33 ![]() ![]() ![]() |
If you have a Nanocom (or access to one), and have not had your ECU remapped, I can do the Cruise Control healing ECU mod for you at zero cost. Rgds Matt 24 yrs of Td5 ownership D110 Td5 MY06 fully tuned up ex-D2 Td5 MY04 Auto ex-D110 Td5 MY00 ex-D2 Td5 MY00 ex-D2 Td5 MY99 ex-D1 300Tdi MY89 ex-D90 200Tdi MY87 |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2209 ![]() ![]() ![]() |
However that will most likely remove any current mapping you have in place.
Most definitely, hence the requisite of not having had the ECU remapped. 24 yrs of Td5 ownership D110 Td5 MY06 fully tuned up ex-D2 Td5 MY04 Auto ex-D110 Td5 MY00 ex-D2 Td5 MY00 ex-D2 Td5 MY99 ex-D1 300Tdi MY89 ex-D90 200Tdi MY87 |
