Home > Td5 > Changed transfer box to 1.2 and cruise control doesn’t wor
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
Hi guys,
I’ve made the cruise control mod a few years ago to my TD5. It worked lovely until I changed my transfer box to a 1.2 ratio. My Speedo still reads correct but the cruise control doesn’t work?
Is there an ECU mod that can be performed to fix this?
Thanks in advance
Post #1039803 12th Jul 2024 8:33pm
Martin
Site Admin
https://www.defender2.net/forum/search.php...edo+healer  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1039805 12th Jul 2024 8:48pm
Mo Murphy
It can be done in the ECU too, negating the need for a speedo healer.
50 Shades of Pennine Grey
Post #1039854 13th Jul 2024 2:02pm
phillips321
Been quoted £130+VAT For the ECU mod but I can get a speedo healer for £85ish
If I go the healer route I assume I put it between speedo and ECU? If so I’ll mount it behind the speedo cluster. Anyone know the correct cable I need to put it between?
Post #1039857 13th Jul 2024 2:28pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I had a similar issue on my TD5, after installing a recon gearbox with the V8 5th gear ratio.
The pulse signal goes from the sender on T-box to speedo gauge where it is multiplied by 2 and sent down to the ECU. In my case, the altered 5th ratio sent a false signal which tells the ECU to cancel the CC due to the signals being out of the parameters.
The speedo read accurately and I didn't want to change that so I installed the unit between the instrument cluster and the ECU near to the main black ECU plug. In this case the red cable on the Speedohealer needs an ignition live, the black cable needs an earth. Cut the yellow/white ECU wire coming from terminal B13 on the black ECU plug, connected the white wire to the speedo gauge end and the green wire to the ECU end. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #1039866 13th Jul 2024 5:55pm
phillips321
Thanks for this.
Post #1039870 13th Jul 2024 7:05pm
phillips321
Any idea if that yellow/white cable goes behind the instrument cluster to the speedo?
Post #1039871 13th Jul 2024 7:06pm
Martin
Site Admin
It's yellow+pink, and is on one of the pink plugs to the speedo.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1039880 13th Jul 2024 8:54pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I put my speedo healer with the engine ecu, I have on overdrive so fitted a 5pin relay to switch the speed signal going direct to the ecu or via the speedo healer.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #1039927 14th Jul 2024 2:32pm
Linds Hanson
I wouldn't put the healer on the speedo feed as your speedo will read slow I better to connect it at the ECU speed input .
Post #1040012 15th Jul 2024 1:27pm
Martin
Site Admin
The yellow/pink is the signal OUT of the speedo, to the ECU.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1040013 15th Jul 2024 1:30pm
mturri
 2006 Defender 110 Td5 CSW Bonatti Grey
If you have a Nanocom (or access to one), and have not had your ECU remapped, I can do the Cruise Control healing ECU mod for you at zero cost.
Rgds
Matt 24 yrs of Td5 ownership
D110 Td5 MY06 fully tuned up
ex-D2 Td5 MY04 Auto
ex-D110 Td5 MY00
ex-D2 Td5 MY00
ex-D2 Td5 MY99
ex-D1 300Tdi MY89
ex-D90 200Tdi MY87
Post #1040416 20th Jul 2024 9:41am
bankz5152
However that will most likely remove any current mapping you have in place.
Post #1040462 20th Jul 2024 1:33pm
mturri
Most definitely, hence the requisite of not having had the ECU remapped. 24 yrs of Td5 ownership
ex-D2 Td5 MY04 Auto
ex-D110 Td5 MY00
ex-D2 Td5 MY00
ex-D2 Td5 MY99
ex-D1 300Tdi MY89
ex-D90 200Tdi MY87
Post #1040463 20th Jul 2024 1:43pm
bankz5152
Laughing Sorry missed that! Easy to without retaining mapping
Post #1040464 20th Jul 2024 1:51pm
