Home > Maintenance & Modifications > Puma airbox removal
Page 3 of 3 <123
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Ehhh which three nuts Embarassed
I have taken the airbox out several times. Yes it's a pig but first undo the bottom grommets, just a bit of wiggling and manly pressure. Than the back ones. Take the top cowl off and slide the airbox under the airco line. Than downwards and out it's comes. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695452 22nd Mar 2018 4:05pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
3 bolts, located horizontally on the inner arch between shock tower and front end of wing. 10mm sized head if I remember correctly. m
Post #695567 22nd Mar 2018 11:15pm
BykerPete
United Kingdom 2014 Defender 110 300 Tdi CSW Willow Green
Same here. I don’t see the three nuts. If they inside the air filter housing then they’re completely invisible to me, or maybe I’m just stoopid? Smile Drink Coffee, Talk to Strangers and Take Photos.
Post #708050 19th May 2018 10:52am
I think that anyone who has had their vehicle in for the Intercooler lower hose Support bracket mod - http://www.defender2.net/forum/topic30113....racket+mod - may well be missing these bolts.
I think they are removed for access to fit the mod, and main dealers being main dealers they have not refitted when the airbox is put back in.
Might explain why so many people can't find them and have no recollection of having them removed?
Post #708755 23rd May 2018 12:43pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
My 2015 110 has the hose support bracket already in place from the factory but the air box support is riveted to the inner wing, not bolted. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #708762 23rd May 2018 1:15pm
Dinnu
Re: Puma airbox removal
Since I found the drawing that I need on this thread, I thought I would post here.
I have my right mudguard off the Defender, and noticed that one of the airbox mounts, #9, part number PYA10008L is kind of perishing.  I thought I would replace, simple.... until a quick search by Mr. Google shows a bonkers price. Lowest I found GB£41.53.
Question is, anyone made / knows an alternative rubber?
I will be in the mean time checking is the VW part number 036129689B is of the right dimension or not. For the price of 1x Landrover part, I could get 40x of those!!!!. But unsure when I can do that Sad
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1039920 14th Jul 2024 11:26am
MK
According to chinese sellers for the VW rubber, dimensions are
D1. 9.8mm small hole
D2. 39.5mm max diameter
No other information Puma 110" SW
Post #1039934 14th Jul 2024 3:36pm
Dinnu
Follow up and for the benefit of those who might be searching or read this, I think that PYA10008L is Ford part number 95BB-9B929-AA which can be bought much cheaper than the LandRover part.
Unfortunately, or fortunately, i have 2 different mounts (damaged mudguard in previous ownership) and the one that has deteriorated is the Ford part.
I compared with the VW part, see my previous post for part number, and they seem to be so similar. Below are pictures of the 3 parts I have. Left is the Ford part, middle is the other mount I found in the airbox support bracket, and the right one is a worn out VW part.
I will try to purchase the VW part, and see how they fit.
Post #1040033 15th Jul 2024 6:56pm
Dinnu
Update. Got the VW rubber mounts, different number on the moulding, but seem correct shape. They fitted a little loosely in the bracket holes, so i fitted an O ring in tge mount grove, and they became a snug fit.
Galvanized and painted the bracket while was out, cause why not.
Post #1046388 21st Sep 2024 11:48am
Page 3 of 3 <123
