![]() | Home > Maintenance & Modifications > Puma airbox removal |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Miserableolgit,
Workshop dont said too much about it 1. Release the air cleaner outlet pipe. Release the clip. ![]() 2 . Disconnect the mass air flow (MAF) sensor electrical connector. Release the wiring harness. ![]() 3 . Remove the air cleaner housing cover. ![]() 4 . Remove the air cleaner element. ![]() Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Thanks Eduardo but I got to that stage without problem. It's the filter housing itself that I want to get out but it refuses to budge even after removing its supporting bracket bolts etc.
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
It needs to be pulled up at the place where it is closest to the engine then pulled horizontally away from the wing.
Well I've again pulled, heaved, yanked, attempted to lever and generally applied as much force as I dare and even with spraying the rubber grommets with lube the thing still refuses to budge. I think I'll end up drilling out the pop rivets that hold the upper bracket in place.
Well all I can suggest is eat more for breakfast and then have a really good tug. Up and towards the engine that is.
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
This is what the book says:
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Hope this helps..... Tim Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Many thanks for that Tim, I had overlooked the 3rd bracket fastener behind the the shock turret and obscured by mud. All sorted now.
Thanks again, Steve |
You're welcome Steve!
Tim |
Edd80Inch Member Since: 18 Oct 2008 Location: Devon Posts: 28 ![]() ![]() ![]() |
In short its a basta*d 1999 90 TD5 County
1943 Ford GPW Jeep |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
I can't even get the top off the air box. It's a LHD and the air box is right under the right hand side wing. I spent an hour trying,but couldn't do it. Now i'm worried that when it goes to the local ford garage for it's first service (in France) they'll just not bother changing it or they'll bend the wing. Is anybody elses under the wing?
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 ![]() ![]() ![]() |
Miserableolgit - How did you remove the housing in the end without damaging the bracket?
My 110 has just come back from the dealer with a broken bracket after removing the housing : ![]() Click image to enlarge I'd be interested in the process you used to remove the housing without this damage. Thanks! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20688 ![]() ![]() |
Carefully drill out the rivets front under nest holding the bracket.
Re-install with short self tapping screws or more rivets, not ideal to remove on a regular basis though. |
I read your posts about the bracket damage Jim
![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Thanks for the tip. So there is no way to remove the air cleaner housing from the bracket in-situ it seems.
Best to drill the rivets and remove the housing and bracket as a combined unit and refit with new rivets. Got it. |
