Home > Maintenance & Modifications > Puma airbox removal |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
Ehhh which three nuts
I have taken the airbox out several times. Yes it's a pig but first undo the bottom grommets, just a bit of wiggling and manly pressure. Than the back ones. Take the top cowl off and slide the airbox under the airco line. Than downwards and out it's comes. a defender from 1984 pretending to be a puma with a touch of Range Rover |
22nd Mar 2018 4:05pm |
BykerPete Member Since: 02 Feb 2015 Location: Midlands Posts: 159 |
Same here. I don’t see the three nuts. If they inside the air filter housing then they’re completely invisible to me, or maybe I’m just stoopid? Drink Coffee, Talk to Strangers and Take Photos. |
19th May 2018 10:52am |
I think that anyone who has had their vehicle in for the Intercooler lower hose Support bracket mod - http://www.defender2.net/forum/topic30113....racket+mod - may well be missing these bolts.
I think they are removed for access to fit the mod, and main dealers being main dealers they have not refitted when the airbox is put back in. Might explain why so many people can't find them and have no recollection of having them removed? |
23rd May 2018 12:43pm |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 |
My 2015 110 has the hose support bracket already in place from the factory but the air box support is riveted to the inner wing, not bolted. Dave
Green Goddess - 1998 Defender 110 300tdi |
23rd May 2018 1:15pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3467 |
Since I found the drawing that I need on this thread, I thought I would post here.
I have my right mudguard off the Defender, and noticed that one of the airbox mounts, #9, part number PYA10008L is kind of perishing. I thought I would replace, simple.... until a quick search by Mr. Google shows a bonkers price. Lowest I found GB£41.53. Question is, anyone made / knows an alternative rubber? I will be in the mean time checking is the VW part number 036129689B is of the right dimension or not. For the price of 1x Landrover part, I could get 40x of those!!!!. But unsure when I can do that 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
14th Jul 2024 11:26am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2443 |
According to chinese sellers for the VW rubber, dimensions are
D1. 9.8mm small hole D2. 39.5mm max diameter No other information Puma 110" SW ............................................................. Earth first. Other planets later |
14th Jul 2024 3:36pm |
Follow up and for the benefit of those who might be searching or read this, I think that PYA10008L is Ford part number 95BB-9B929-AA which can be bought much cheaper than the LandRover part.
Unfortunately, or fortunately, i have 2 different mounts (damaged mudguard in previous ownership) and the one that has deteriorated is the Ford part. I compared with the VW part, see my previous post for part number, and they seem to be so similar. Below are pictures of the 3 parts I have. Left is the Ford part, middle is the other mount I found in the airbox support bracket, and the right one is a worn out VW part. I will try to purchase the VW part, and see how they fit. Click image to enlarge Click image to enlarge Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
15th Jul 2024 6:56pm |
Update. Got the VW rubber mounts, different number on the moulding, but seem correct shape. They fitted a little loosely in the bracket holes, so i fitted an O ring in tge mount grove, and they became a snug fit.
Galvanized and painted the bracket while was out, cause why not. Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
21st Sep 2024 11:48am |
