![]() | Home > My Defender > Project: La Jefa - 2.2 Puma |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1852 ![]() ![]() ![]() |
I love the look of a Tonka Toy, not sure I could live with the on road manners and noise though.
Good luck with sorting the faults, but I'd have thought talking to a suspension specialist like Glynn Lewis or similar would be a good first step. Keith |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8221 ![]() ![]() ![]() |
I expect it running std rear trailing arms hence axle is forward.
Diff noses could be high unless they have been corrected which can make them run low on oil, depending on diffs fitted. A frame ball joint could also be near max droop when she's sat flat and run out of travel and bind on further droop. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
iamdimitris Member Since: 03 Oct 2018 Location: Limassol Posts: 43 ![]() ![]() ![]() |
to be honest, right now road manners are terrible - extremely noisy and the handling is quite unstable |
Correct regarding your first point. Do you think that the TR236 would give an overall improvement? |
Regarding intercoolers I have hear mixed feelings about the allisport ones.
someone suggest the BAS HI-FLOW one. what have your experiences been? |
for the love of God, could someone tell me how to remove these screwlessmJwSpeaker front turn signal lights?
![]() ![]() ![]() Click image to enlarge |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge some more photos of the lights driving me crazy. I know its probably a simple click, just don't wont to force and break them somehow |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 917 ![]() ![]() ![]() |
I think the JW Speaker lights and indicators have their fixings on the back side. So you’ll need to get at them from behind. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2469 ![]() ![]() ![]() |
If you think on keeping that setup (I would not. Way beyond any design) only a serious damper like abespoke king, fox, etc will manage such suspension. I think you just will waste your money on those TF. Puma 110" SW
Thank You, ill check properly later. but from a quick check yesterday I couldn't see a proper access from inside to the front wing turn signal |
do you have a link? couldn't find from a quick search ps. regarding the setup - yes it is a bit extreme but I got it already like this. its not a daily driver and might cost me more to 'downgrade' the setup. I am waiting to change the tyres and wheels and see it from there |
Only in the US. Downsouth motorsports. Very helpful. Puma 110" SW
anyone knows what is the part number/name for the original retainer clips for the tail light screws?
If anyone might need the info in the future it is the:
Nut Sert Plastic. Part No. RTC3745 ![]() |
