Home > General & Technical (L663) > Who's changed their oil |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 431 |
Next time be prepared to install the Fumoto drain valve.. saves a lot of time each oil change https://landroverforums.com/forum/2020-def...post884592 No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
7th Jul 2024 12:04pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2867 |
Now that's an accessory worth fitting.
7th Jul 2024 8:33pm |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 134 |
For me the valve location plus an access port / hole increases the risk of it getting knocked and losing all the oil. I do like the idea of a bolted on little cover plate though...
9th Jul 2024 1:47pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1089 |
Don't want to be a party pooper, but I would not go under an air suspension car without some sort of a prop. It does not even have to touch, just something stronger than your head.. I have had (still have) air suspension cars and of course I never had them drop, but I can imagine that you could disturb something a height sensor and it could drop. |
10th Jul 2024 3:33pm |
Definitely, regardless of EAS or std suspension, you never get under a car without it being propped. Gravity wins everytime, especially with a 3t 4WD.
11th Jul 2024 4:14am |
johnlad Member Since: 18 Dec 2023 Location: Blackpool Posts: 54 |
Just got the correct oil for D300 oil change from Halfords,
The Castrol edge titanium 0w-30 E, Works out at £13 a litre with the trade card. Don’t know if that’s any use to anyone but it was the cheapest I could find. |
19th Jul 2024 7:17pm |
JonathanP Member Since: 01 Jun 2024 Location: Barnard Castle Posts: 22 |
Hi
What is the correct oil please for a D250 as my handbook says it is Castrol Edge Professional 0-30 |
19th Jul 2024 8:37pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1418 |
According to the handbook for my D200 the correct oil is SAE 0W-30 meeting Jaguar Land Rover specification STJLR.03.5007. For those that don't have a trade card Halfords have 10% extra discount on motoring items which takes the price of Castrol edge titanium 0w-30 E (meeting Jaguar Land Rover specification STJLR.03.5007) down to £12.95 per litre Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
30th Jul 2024 2:59pm |
Thanks for the help but when I look on Halfords website Castrol edge titanium 0w-30 E does NOT meet Jaguar Land Rover specification STJLR.03.5007 ?
Then when I look on the Castrol website the only reference is Castrol Edge Professional which seems to be different to Castrol Edge Titanium ?? You are correct, I have now found the reference in the I Guide and the oil required needs to be SAE 0W-30 E meeting Jaguar Land Rover specification STJLR.03.5007 but that seems to be for Castrol Edge Professional grade not the Castrol Edge Titanium grade ?? Am I reading this correct please? Thanks Jonathan |
30th Jul 2024 11:15pm |
This is the photo of the container on the Halfords site.
Click image to enlarge and this is from the specification Click image to enlarge So according to Halfords it does meet STJLR.03.5007, where are you seeing it doesn't? https://www.halfords.com/motoring/engine-o...28019.html Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
30th Jul 2024 11:24pm |
Ok Thanks, but that photo is Castrol Edge Professional, which is the correct oil, but I think Castrol Edge Titanium is different and not JLR approved
From Halfords website Click image to enlarge Castrol Edge Titanium 0W30 Oil 4 Litre The Castrol Edge Titanium 0W30 Oil features the latest specification for Vauxhall, BMW, Mercedes and most other modern engines. The fully synthetic technology provides the best oil for modern high performance engines, protecting from the moment you start the engine. Castrol EDGE 0W-30 with Fluid TITANIUM physically transforms its structure – becoming stiffer at points of extreme pressure, keeping metal apart and reducing friction. When the pressure subsides, the oil reverts to its free-flowing state. Stronger under pressure, Castrol EDGE with Fluid TITANIUM transforms its structure and reduces performance-robbing friction by 20%*. Features & Benefits: Oil viscosity 0W30 Fully synthetic technology Transforms to be strongest when the pressure is highest, protecting your engine Reduces power-robbing friction across engine speeds and conditions Protects the engine for the entire drain interval even under extreme pressure Suitable for BMW Longlife-04, GM-LL-A-025, GM-LL-B-025, MB-Approved 229.3, MB-Approved 229.5, VW 502 00 / 503 01 / 505 00 Renault RN 0700/ RN 0710 dexos2™* Certifications & Standards: ACEA C3 API SM CF Additional Note: Please note that packaging and label supplied may differ from web image but the contents are the same |
31st Jul 2024 10:02pm |
It's not just oil any more.
l remember when there were only two choices, and either was fine in any engine. I wonder what would happen if you used a NOS can of Castrol GTX or Duckhams Hypergrade in a New Defender. Would the engine sieze, or blow up. Or would it run fine, but be ruined within a few thousand miles. There's a few videos online of engines being run on stupid stuff like cooking oil, to see how long they last (not long) It would be an interesting test to run a modern engine on 1980's oil that meets none of the modern specifications, and see what happens. lt would certainly be more worthwhile than the guy on Youtube who buys new exotic cars like Ferrari and then just smashes them up. |
1st Aug 2024 7:18am |
When you look into oil specs you will find that a lot of the quality (apart from the obvious viscosity) is related to ash and how this might interact with your emission system. The wrong oil can mess with all of that which can get expensive quickly.
But all of this is standardized and an oil meets it of not, including 'Tesco oils'. Then there is some longevity, change interval stuff, which is about additives and stability (cost). Finally, but most importantly, just like for your dishwasher there are marketing agreements between manufacturers which push certain brands. Landrover pushes Castrol (BP) have done for a long time. They probably get their oil cheap as long as they can convince you and I to pay a premium price for oil over the lifetime of the car. We are being sold out basically. Often the exact same engine used by different car manufactures have different branded oil recommendations. Personally I just learn the spec and buy accordingly. My change intervals are always less so I am not too worried about long life bs. |
1st Aug 2024 9:23am |
Kaz Member Since: 14 Aug 2024 Location: America Posts: 13 |
I use Mobil 1 in all of our gas powered vehicles, and we stick to 5K intervals unless breaking in an engine.
0-20 in the winter as we get some brutal colds around here, and 0-30 / 0-40 in the summer. A side note on Fumoto valves. They are the way to go for easy oil changes. We use them in all of our off-road going vehicles. |
15th Aug 2024 1:12am |
