Home > Technical > Can't engage gears (R380) |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 625 |
Have they tried what I suggested?
It is physically impossible to fit a Tdi clutch plate backwards, the pressure plate wouldn’t clamp up. |
2nd Jul 2024 8:54pm |
anotherrick Member Since: 02 Feb 2024 Location: Lancashire Posts: 30 |
Going to ring later to see where he's at and what he's tried.
3rd Jul 2024 8:14am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3430 |
The clutch cover can be mounted at 3 different angles to the flywheel, so at every 120degree. It does not matter which one you choose. 60degree is exactly half the 120degree. So if it is mounted 60degree shifted, it means the dowel pins are not being used. If that is possible, I am unsure, depends if the 6 bolt holes for the clutch cover/flywheel are equally spaced. What would happen if possible to be mounted that way I am not sure though. As said before, the design and the location of the springs on the friction plate will not let the cover even get close enough to the flywheel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
3rd Jul 2024 10:33am |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
What was the result of this?
15th Jul 2024 9:26pm |
The spigot bush snagged on the way in causing a number of other issues inc damaging the clutch plate beyond repair.
17th Jul 2024 9:09am |
oooh...bu99er...sorry to hear that. Hopefully the garage are doing the right thing thing and are sorting out their issue? They must have been pretty brutal when mating the gearbox to the engine to do that.
17th Jul 2024 9:19am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5732 |
Wow. That is quite an achievement. Sorry for you. Assume it isn’t costing you are more money. |
17th Jul 2024 11:01am |
Yeh all sorted now. Now extra charge from the garage doing the work and the guy from lof was also more than helpful 👍
30th Jul 2024 6:12pm |
Luke is a great chap
30th Jul 2024 7:59pm |
