Home > Maintenance & Modifications > Gear knob!
CarMan
Gear knob!
Sorry guys not very exciting, but the 'original' one on my 200tdi has stripped the thread I think and hopefully in the plastic knob. I can of course buy an aftermarket replacement ridiculously cheaply but otherwise it's good I don't really want to go new.
I have tried lock-tite which hasn't really worked and I don't want to araldite it in place forever, so was wondering if any of you guys have any suggestions to fix it in place semi-permanently.
Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #1038290 24th Jun 2024 5:53pm
ickle
a Helicoil?
If you can find the thread size & re tap the knob
hth Keith
Post #1038292 24th Jun 2024 6:05pm
landy andy
I have never done it but…….
Heat the shaft with blow lamp, or similar, get it nice and hot, then shove knob on. Heat melts the internals of knob to the thread on shaft.
Post #1038297 24th Jun 2024 6:41pm
Dinnu
Apply some ptfe tape on the gear stick and use araldite. The epoxy does not stick to ptfe. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1038298 24th Jun 2024 6:44pm
CarMan
Thanks guys for the quick responses, some great ideas there:
ickle - you really have no idea of my (lack of) skills!
landy andy - as above and I'm not keen to experiment in case it is there forever, plus I don't have a blowlamp and my wife's hairdryer isn't up to the job and is worth many times more than a knob!
Dinnu - I like that idea, but initially I am scared by the araldite so think I'll try the ptfe (which I have) as a starter, thanks
Otherwise a wanted add for second hand knob, but seriously a new one is little more than the postage, but as there is little new on the truck now I am very loathed to go that route.
Thumbs Up
Post #1038299 24th Jun 2024 7:02pm
Dinnu
Dont put too many layers of ptfe, just one or two, and wrap it tight so you maintain the thread profile.
I tried it with bolts in epoxy, and they undo themselves so easily once the epoxy is fully hardened. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1038301 24th Jun 2024 7:11pm
CarMan
Thumbs Up thanks
Post #1038302 24th Jun 2024 7:16pm
ashcurrie
United Kingdom 1992 Defender 90 200 Tdi SW Santorini Black
I had this issue a few years ago and used Mike from Britannica Restorations method to sort the problem permanently - https://youtu.be/L6IxTUMQlEg?si=mR3T7Pt1mhnXWIN8 1992 Defender 90 SW 200Tdi
2008 Defender 110 USW
Post #1038340 25th Jun 2024 9:05am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Post #1038394 25th Jun 2024 6:49pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
You should definitely go 8 ball like I did. Same problem as you on my 300tdi. The pool ball fits perfectly in the hand and adds a bit of cool. https://www.defender2.net/forum/topic92150.html
I was wrong in the thread, 300tdi uses 1/2" UNF for the gear stick.
Post #1038419 25th Jun 2024 10:49pm
rustandoil
Is this now sorted?
Post #1038456 26th Jun 2024 1:01pm
CarMan
Nope, haven't had a chance to look at it yet, work getting in the way Rolling Eyes
Post #1038457 26th Jun 2024 1:07pm
rustandoil
Have you got a Dremel?
Post #1038523 27th Jun 2024 4:32am
CarMan
No but I've long wanted an excuse to buy one!
Post #1038524 27th Jun 2024 5:16am
rustandoil
Haha.... Perfect!
Post #1038525 27th Jun 2024 5:34am
