Home > Maintenance & Modifications > Gear knob!
Page 2 of 2 <12
rustandoil
.... Then you need a friendly local machine shop to make you one of these 😉😎
Post #1038526 27th Jun 2024 5:37am
Dinnu
There is no need of a dremel, or any drilling as a matter of fact, as the hole inside the knon is quite large. Land Rover used sort of a rubber insert, and that crumbles and falls away.
For mine I turned a 1/2" UNF nut to the right size and simply press fitted in in the knob. No modifications to the knob other than cleaning off the crumbled rubber. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1038527 27th Jun 2024 5:59am
Page 2 of 2 <12
