Home > Td5 > Should I rebuild short engine |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1352 |
i'm a firm believer of if it isn't broke, don't try fix it.
given it's mileage, if it has a good service history i would leave alone. i have seen TD5's at over 200k and being fault free. they like oil changes and mine gets one annually which varies from 1k to 5k miles. |
3rd Jun 2024 4:32pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 731 |
As above - I’d leave it alone if it’s running fine. 2008 2.4 110 Utility Station Wagon XS.
3rd Jun 2024 6:23pm |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 879 |
160,000 miles is nothing on a Td5. I would leave the bottom end well alone, other than checking the oil pump sprocket bolt. Treat them to good oil and filters every 5,000 miles or so, and they will return the favour. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
4th Jun 2024 7:44am |
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 101 |
Thanks for the replies guys. I guess I was obsessing a bit much as my next trip is around Africa. I had only a few small minor issues in Lapland which were easily solved, and it got me thinking would they be easily solved in Africa
4th Jun 2024 4:19pm |
i think the biggest issue you'll have out there will be poorer quality diesel.
5th Jun 2024 10:12am |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5058 |
If its healthy, id leave the bottom end a lone. Id put the wages into something else for it, that it needs, or you fancy doing. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
23rd Jun 2024 2:16am |
