Home > Td5 > Should I rebuild short engine
Inguz
I've been toying with the idea of rebuilding the bottom end. I already put a new AMC head last year.
Now there is no real signs of anything wrong with the engine but I overland full time most of the time so want it in top condition. I will have a few months with a garage coming up so I was thinking of doing it.
As I said not much sign but a few things have been going as the miles get up, just the typical like exhaust manifold, crank pulley.
I will be doing other work like installing central locker, and I want to put a hybrid turbo with remap.
It's just creeped over 160K with me putting on only about 20k.
So would I be just wasting money or would it be worth doing?
Post #1036385 3rd Jun 2024 2:18pm
AJC
i'm a firm believer of if it isn't broke, don't try fix it.
given it's mileage, if it has a good service history i would leave alone. i have seen TD5's at over 200k and being fault free. they like oil changes and mine gets one annually which varies from 1k to 5k miles.
Post #1036392 3rd Jun 2024 3:32pm
BrickBox
As above - I’d leave it alone if it’s running fine. 2008 2.4 110 Utility Station Wagon XS.
Post #1036398 3rd Jun 2024 5:23pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
160,000 miles is nothing on a Td5. I would leave the bottom end well alone, other than checking the oil pump sprocket bolt. Treat them to good oil and filters every 5,000 miles or so, and they will return the favour. Thumbs Up Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1036440 4th Jun 2024 6:44am
Inguz
Thanks for the replies guys. I guess I was obsessing a bit much as my next trip is around Africa. I had only a few small minor issues in Lapland which were easily solved, and it got me thinking would they be easily solved in Africa
Post #1036485 4th Jun 2024 3:19pm
AJC
i think the biggest issue you'll have out there will be poorer quality diesel.
Post #1036541 5th Jun 2024 9:12am
Procta
Re: Should I rebuild short engine
If its healthy, id leave the bottom end a lone. Id put the wages into something else for it, that it needs, or you fancy doing. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1038172 23rd Jun 2024 1:16am
