![]() | Home > Maintenance & Modifications > Tinting double cab windows |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5849 ![]() ![]() |
When I had my DC I had a professional place do it for me. They did remove the glass to do it.
But the chap said it was horrible and if it didn’t work , he would recommend just painting the glass black on the inside, which could always be scraped off with a blade later if required. |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
That’s what I was afraid of. If a pro can’t manage it then I’m stuffed!
Did they turn out ok though? 2002 110 td5 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20699 ![]() ![]() |
https://vehicleglazingspecialists.com/inde...uct_id=291 TheThunderRolls🇬🇧🇺🇸
Yes. But it did cost a lot. ![]() |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 810 ![]() ![]() ![]() |
Mine was done by the dealer from new 19 years ago...... A little bit of peeling on the bottom of one...
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2660 ![]() ![]() ![]() |
In the past you used to be able to get a spray tint for rear lights.
Might be worth seeing if it works on glass.. Found this on Amazon and can be used on glass E-TECH ELS150-SMOKE Lens Tint Spray - 150ml https://amzn.eu/d/01tmHvIj I guess you keep over spraying it to get the level of tint you need. |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1727 ![]() ![]() |
My window tinter I always use did. mine £50 the pair, perfect finish. Ask around and find a pro Defender puma dormobile camper
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 505 ![]() ![]() |
Can be done with lots of patience we had a pro try and fail so just persevered ourselves
I had another go tonight and it was alot better. I am learning to “read” The film a little bit more now. I’ll just keep going until I get it perfect (ish).
If I do get it right I’ll post some pictures. If I don’t, I’ll keep quiet 🤫 2002 110 td5 |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1179 ![]() ![]() ![]() |
I had mine done about 6/7 years ago
The curved cab windows are a pain with normal film, my guy used a perforated film which gives much more “flexibility” for the shape of the glass I don’t have any close up pictures, but it’s unspottable from a couple of feet away fitted ![]() Click image to enlarge My confidence has been writing cheques that my abilities can't cash for years. |
I’ve lost enough time to this already so I opted to do it in two halves.
![]() Click image to enlarge ![]() Click image to enlarge Thanks for all the advice. If I can’t live with the line I’ll have a look at the perforated film 2002 110 td5 |
Use a sharpie marker pen along the joint. It will hide it, and can be removed later if required
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 149 ![]() ![]() ![]() |
Get some pre-tinted poly units from vgs.
