Home > Td5 > Td5 2003 starting issue
roche1800
It has always started first time UNTIL this morning when it would not!
The battery is charged and when the ignition is turned there is one click and nothing else, it has bump started.
My son took it to help in the village and left it running while dropping something off, he said it spluttered and then stopped.
Again the key turns and just a click, bump started to get it home.
Hopefully you guys point me to solenoid or starter or ….
Look forward to some help to solve the issue. Many thanks in advance.
Post #1036921 9th Jun 2024 1:57pm
landy andy
It sounds like the solenoid on the starter.
If so you can rebuild solenoid, get stater off and get it rebuilt, or fit new starter.
Post #1036931 9th Jun 2024 2:51pm
Check the grounding points and battery clamps are tight and clean, you’d be surprised how common these issues are especially the transmission connection and it’s not always the Starter.
Worth checking just in case first. TheThunder Rolls🇬🇧🇺🇸
Post #1036936 9th Jun 2024 3:19pm
roche1800
So I have inspected earthing and undone and cleaned terminals on motor and nothing.
Removed last night and here are photos inside solenoid with signs of wear ….
Post #1037093 11th Jun 2024 9:55am
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I fitted this kit about 4 years ago, no problems since. There is a bolt that is a pain in the backside to get out, other that that, not a bad job.
https://x8r.co.uk/land-rover-discovery-td5...r-kit.html
Post #1037247 12th Jun 2024 7:53pm
roche1800
Cheers, fitted the refurb kit and the click is way better. Sadly done a bench test and the cog shoots out but doesn’t spin Big Cry
Post #1037258 12th Jun 2024 9:38pm
