![]() | Home > Td5 > Faulty ECU causing cutting out and killing camping trip ! |
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 101 ![]() |
Have you checked the red plug for oil?
N5tys Member Since: 26 Aug 2023 Location: Portsmouth Posts: 22 ![]() ![]() ![]() |
thanks for the rely , i did change the injector harness when i purchased the truck last year though did not open the ECU its self maybe its worth prising it open ? just a bit worried that i cant trust it now without getting it looked at ?
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 500 ![]() ![]() |
Sounds like a capacitor issue have you read any fault codes? They usually show as a top side switch fault. If you loose the glow plug light and temp gauge then check the relays are making a good contact under the drivers seat.
thanks , i have checked the relays though all seam to have a good connection , when you say capacitor do you mean within the ECU its self ? it was definitely the tap on the ECU that sorted it .
sorry forgot to mention unfortunately i have no way to check for fault codes the truck is running again now but the same issue is bound to happen again
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 642 ![]() ![]() ![]() |
It looks more like problem in wires/connectors/sockets than in ECU.
I have repaired quite a lot of TD5 ECUs, and it was never susceptible to any mechanical movement. Check wires, connectors, relays and relay sockets for any signs of corrosion or burn marks. But before any big work, try someone with Nanocom to read faults and check live data. Without this, you are "blind". "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 795 ![]() ![]() ![]() |
Dan at Storm Tuning in Rotherham tests and repairs TD5 ecus.
Can vouch for his work, we have had a couple of customers issues sorted by him with ECUs and where he hasn’t been able/hadn’t been cost effective to repair he can usually supply a tested second hand unit from stock. Chris |
thanks for the help that is great ill try and find someone in the south area that has nano and double check wiring
