Home > My Defender > a 130 itch
Page 20 of 21 <123 ... 192021>
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Looking good, you may have mentioned it before and I can’t see it but what version engine and box did you go for and what was it out of? Looks like the n2 and 8hp going by the shifter or do can you get 6 speeds with that style?
Post #1033901 5th May 2024 7:07pm
jst
Yep n2, 231bhp with 6hp28. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1033906 5th May 2024 8:34pm
Looks great James, just read through the early stages pages start to finish which took a while. Thumbs Up
I think it’s easy to underestimate the time and effort these things take to get just right, along with everyday life getting in the way as well years can go by. Laughing
Have you thought about what kind of exhaust system you’ll go for or have you not quite got to that stage yet? No Guts, No Glory.
Post #1033908 5th May 2024 9:11pm
jst
Sorry, I typed a long reply to this, thought I had posted it and it's now lost!
Thank you, its been a long time in the thinking for the camper element. Seems to have turned out alright though.
The m57 change came about after I did my 90 and thought well that was pretty straight forward and what a difference. The 130 fully loaded up makes for a sluggish beast, hence the 1.3 t box. So m57 seemed a good option. Note though that the 80k 2.4 is sat not going anywhere just yet, along with the manual gbox!
I have a 2.5" downpipe with the mountings for the various sensors.in it which then plumbs into the existing 2.4 2.5" std system with both boxes. Runs a treat like that.
Currently using it as my daily driver to get some miles on her. Tows a dream. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1034236 8th May 2024 8:28pm
jst
Well she's going really well.
With roof tent, top box, store draw filled, 80l water tank, fridge, 3 batts and all the other camping stuff she drives so well compared to before. I have found myself using it more as a daily driver lately, one, because its new to me engine and exciting, two, because its soo easy to drive.
Similar economy to previous 2.4 manual of not a little better with normal daily use, better mpg when towing to date.
About 2k miles in so far. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1034987 17th May 2024 8:24am
jst
A good test for the vehicle yesterday a 160 miles towing about 2.5t steady 60 miles an hour gave me engine temperatures around 95° popping up to 98 on a long climb and dropping rapidly once the power had been taken off overall consumption still coming at a healthy 21 mpg when towing about 2 to 3 mpg better than the old 2.4, Mpg normal road routes is 25.9 for the 1750 miles its done with me so still 2 to 3mpg better than 2.4 in normal use.
Much more relaxing to drive and far more responsive too . Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1035227 20th May 2024 2:13pm
tommobot
May I ask what fan / rad setup you are using?
I've tried the viscous unit, but found it couldn't provide decent cooling at all.
Gone for massive radiator and electric fans that will hopefully provide cooling for trips to Europe..
Post #1035234 20th May 2024 3:30pm
jst
its doesnt have a viscous as std on the 231. my 184 does and have changed that to electric currently.
Its running an Allisport M57 specific rad and intercooler. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1035257 20th May 2024 6:26pm
lb73
Wales
Good to hear it’s going well. Interested in the air filter set up, looks like you’ve got an adapter on the standard air box? Also are you running a pre filter between the tank and pump. I’ve got the main filter between the pump and the engine, but was considering some sort of filter to protect the pump. Cheers 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2002 Dax Rush 3.9 V8
2012 Audi A3 tdi
2020 Renault Kangoo electric
Post #1035272 20th May 2024 9:14pm
jst
Marcus at MW4x4 machines supplied the parts for the conversion, brilliant service and great parts. I also ordered the air filter adaptor from him which is whats fitted.
It currently goes to a nugget box - but may change that.
I dont have a pump filter fitted. It goes tank - pump - filter - engine - tank Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1035298 21st May 2024 8:00am
lb73
Wales
Thanks for the reply Thumbs Up 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #1035540 24th May 2024 6:40am
jst
Great test for truck fully loaded 4.5hr drive. Really liking the auto matched with this engine. Economy same as 2.4 manual on this trip. All set up ready to go!
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1035706 25th May 2024 6:33pm
jst
So far so good with the conversion.
However, there has been one bug bear, charging.
I have now sorted this but thought i would share the problem first.
Start the vehicle 14.2 or 14.3v direct to battery. output stays at that for however long the vehicle is left in Park and engine running. revving the engine see slight increase then steadies at 14.2. load the vehicle electrically. ac. heater fan 3, heated seats, lights and it stays at 14.2
voltage taken from scan gauge and DVM straight off battery and off stud on alternator. 0.1variation between them.
Move the gear stick to R or D and it drops to between 12.8 and 13.2v and fluctuates around there until the vehicle is turned off. sometimes i see 12.5 and sometimes 13.5 but rarely. my recent 5hr drive and it stayed in the 12.8 to 13.2 range.
the original vehicle had a smart controlled alternator.
i have a VSR (thats clicks in and out alot with this problem) controlling charge to aux batteries.
i have 200W solar feeding the aux batteries and then through to main battery via VSR when correct conditions are met.
So to date no problems starting despite low charge to main battery. (solar providing charge)
problem remains if aux, VSR, solar are all disconnected.
sense wire to alt removal makes no difference to output after alternator has started to produce 14.2v (ie disconnect it prior to start up and alt not excited to produce output)
So what do people think was the problem? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1036022 29th May 2024 7:05pm
jst
Time moves on m57 has been superb. Lovely cruising better economy over the 2.4 too. About 6k miles in since conversion now and loving it.
I have been working on cooling of late. Runs at a nice 90deg normal use and loaded up for camping. She's heavy at this point.
I normally sit at 60ish, 1800rpm. Did a couple of spells at 70 2200rpm and she runs cooler by 5 deg or so on head temp at faster speed. So then tried 60 at a lower gear and at circa 2300rpm she's the same 5 deg cooler.
So although pulls 60 and seems happy must be labouring a little and increasing heat. She's 3mpg better at 60 than 70 over a 120mile.motorway run.
So did some investigating. Seems to be a large variation in opening temps on stats from reputable supplier plus a varying degree of how much they open, same brand, 10deg variation on start opening and 8mm variation on how far they open!
Greater flow needed at lower engine speeds is the aim so experimenting with stats now to open early.enough,.but not too early, and have enough flow past. Will also look at electric water pumps. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1045845 15th Sep 2024 9:37am
jst
Carl Davies EWP on the way! Very Happy Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1046461 22nd Sep 2024 11:15am
