Home > Maintenance & Modifications > Where to Grease
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
Where to Grease
New Puma owner here, where are the key areas with and without nipples to regularly grease up?
So far I have the Propshafts, trackrod end, swivel joints, door hinges? Looking to accumulate a list for an annual top up!
Post #1034477 11th May 2024 4:46pm
A frame ball joint if* it is a greaseable type. (Emphasis upon if it is).
Light oil the turbo actuator pivots.
When you say props, if earlier type that includes the central slider and UJ each end of the Prop.
If there isn’t a slider nipple (in the centre) then each UJ each end.
You can see if you have a thread in the clutch pedal box to fit a nipple in there, it’s on the RHS.
If you do, it only really needs one pump of grease rarely or you’ll end up with a gloop of it on the floor. KEEP CALM AND Drill ON
Post #1034480 11th May 2024 5:04pm
Phillywilly72
Thanks
Post #1034512 12th May 2024 7:32am
landy andy
Lub the steering shaft uj’s too.
You may have grease points on the steering ball joints.
Post #1034513 12th May 2024 7:39am
