Home > Maintenance & Modifications > Where to Grease |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20573 |
A frame ball joint if* it is a greaseable type. (Emphasis upon if it is).
Light oil the turbo actuator pivots. When you say props, if earlier type that includes the central slider and UJ each end of the Prop. If there isn’t a slider nipple (in the centre) then each UJ each end. You can see if you have a thread in the clutch pedal box to fit a nipple in there, it’s on the RHS. If you do, it only really needs one pump of grease rarely or you’ll end up with a gloop of it on the floor. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
11th May 2024 5:04pm |
Phillywilly72 Member Since: 29 Apr 2024 Location: Wiltshire Posts: 70 |
Thanks
12th May 2024 7:32am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5787 |
Lub the steering shaft uj’s too.
You may have grease points on the steering ball joints. |
12th May 2024 7:39am |
