Home > Puma (Tdci) > A Slight Problem for me, A big problem for LR. |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
19th Nov 2011 10:45am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5006 |
19th Nov 2011 1:58pm |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
I've got that cracking all along the front seam on my 22 yr old 90 and it doesn't leak water in (not from there anyway ) its coming in a few more places on the roof and getting into the side gutters, so when I have inclination I'm going to strip out the saggy headlining and seal it all from the inside as well as the outside, I'm hoping it will be easy to see where its coming in with no headlining. I'm suspecting the exterior ribs as when parked on a slope (pointing uphill) and the roof is dried off after rain, there is still water running down the windscreen outside when moving off downhill, so the only place it can be hiding is inside the ribs.
It's fine when I park it pointing downhill, so in the mean time I know what to do. DJ |
29th Nov 2011 6:38pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4615 |
Good luck with that! Our series 111 has no headlining and I still cannot find out where the water gets in! It lies in the internal gutter till you hit a corner or a slope then makes itself known. 1982 88" 2.25 diesel
29th Nov 2011 10:14pm |
elz Member Since: 23 Nov 2009 Location: Weybridge,Surrey Posts: 23 |
All sorted. Dealer took vehicle back, so what to buy next.
6th Dec 2011 4:33pm |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 |
Elz - I have had the same thing on my roof although I use a full length roof rack and I assumed that as I tightened the rack up it pulled the rails up into straight (mine were all over the place).
I got mine repaired and just expect this sort of issue. I suspect that you might always be disappointed with a Defender until the new one comes out. You will always find something you hadn't spotted before. |
6th Dec 2011 10:14pm |
Estate agents call that "charm" Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
6th Dec 2011 10:19pm |
